Where to buy O2 simulator
Old Aug 27, 2006 | 09:48 AM
Ryu123's Avatar
I'm planning on lower by Evo next week and with the rear O2 going into my exhaust at the 4/5 o'clock angle, I'm afraid it will get damaged once the car is lowered. I need to get a O2 simulator that will allow me to remove the sensor all together and just plug up the hole.
I've searched and all I'm able to find is the Perrin. Are there any others?
TIA
Old Aug 27, 2006 | 09:50 AM
4TUN8's Avatar
It wont get damaged.
Old Aug 27, 2006 | 09:58 AM
2theMAX's Avatar
Perrin is the only one that I've heard of........
Old Aug 27, 2006 | 10:32 AM
deegaw11's Avatar
dont worry about it my car is lowered also with the o2 going in my exhaust
Old Aug 27, 2006 | 05:57 PM
Ryu123's Avatar
bump for more input
Old Aug 27, 2006 | 06:00 PM
idriveanevo's Avatar
it will be fine lowerd.... its still above the bottom of the dp, but so far perrin is the only cel fix unless u use a fouler
Old Aug 27, 2006 | 06:01 PM
btw you will still need the o2 even with the perrin cel fix
Old Aug 28, 2006 | 12:26 AM
tboboy's Avatar
I have an AMS TBE and with mechanical fix the o2 sensor was hanging too low (only one anti fouler). I didnt even try to put the second one. So i got perrin 02 simulator,no cel for 300 miles so far. Hopefully will work for a lot longer.
Old Aug 28, 2006 | 12:34 AM
fromWRXtoEVO's Avatar
I guess that not many people are familiar with other different types of o2 simulators uh?
Give me 2 minutes and I will post the pic of my o2 simulator from my own car. It is a mechanical/metal plug that puts a gap between the real o2 sensor and the exhuast piping therefore fooling the o2 sensor reading.
My simulator is plug and play. You screw the o2 senor to the plug and the plug to the exhaust. No cutting, no splicing, no special tools, clean, cheap, simple and efective.
Carlos
Old Aug 28, 2006 | 01:33 AM
evoibad's Avatar
Hey where did you buy that piece.
Old Aug 28, 2006 | 01:34 AM
cadawg2000's Avatar
www.o2simulator.com
They sell a cheap electronic fix..
Old Aug 28, 2006 | 02:34 AM
Contact www.iaperformance.com, their number is (520) 8822821,ask for Stephen.
Carlos
Old Aug 28, 2006 | 06:49 AM
Ryu123's Avatar
So do you still have the O2 sensor installed or is it removed completely with the Perrin fix?
Old Aug 28, 2006 | 06:52 AM
Ryu123's Avatar
Carlos
Thanks for the response Carlos.
My problem is the way the bung is welded on my pipe. If using a clock as reference, my O2 sensor is going into my exhaust pipe at about the 4/5 o'clock position. This in essence makes the end of the O2 where the wires come out the lowest point under my car. I need to find a fix where I can remove the O2 sensor completely if such a fix exists.
Old Nov 15, 2006 | 06:07 PM
diablo2184's Avatar
Carlos
Carlos, you are running this mod you did and no CEL? I see the engine mods you have and i just want to know how long you have been running with the 02 fix and if you have had any problems. I am about to do my exhaust and this looks clean and factory, so let me know. thanks
