Transfer case fluid on driveshaft....where is it coming from?
Old Sep 19, 2006 | 07:49 AM
revvin9k's Avatar
I recently changed all my drivetrain fluids and just happened to notice one small drop of what appeared to be transfer case fluid.
So, I thought I had not tightened down either the fill or drain bolt. So i jack up my car
and crawl under neath it only to find that there are no residual marks ANYWHERE of any fluid near or around either bolts. I Simple Green everything after i'm done with fluid changes and there was no fluid that seemed to travel anywhere to where the drip was. I did notice one even smaller drip on the first half of the drive shaft, and the other was where the first set of hangers are for the exhaust, just before the cat. Again understand, I looked at all possibilities of where the fluid may have traveled from and found none.
I also posted this in another thread but had no responses.
Pic of the drain (no residue):
Terrible pic of the fill bolt: (no residue):
Old Sep 19, 2006 | 07:58 AM
EVIL_EVO_VIII's Avatar
Well it might be that a little dripped on the driveshaft when you initially changed the fluids?
Old Sep 19, 2006 | 08:29 AM
revvin9k's Avatar
How would I get the fluid on the drive shaft?
Everything is always Simple Greened after I am done with fluid changes. I have actually wiped it down and gone out and come back to find it again.
I thought I may have over filled it so I just went and drained my TC and refilled it with Dia Queen, lowered the car and let it dribble out , then put the fill plug back in.
Any other ideas?
Old Sep 19, 2006 | 10:48 AM
revvin9k's Avatar
Well, hoping that I had over filled it, I drained the fluid out again and refilled it w/ Dia Queen. Cleaned everything up w/ Simple Green and took the car for a drive. Came back and the drip is back. If I leave it alone, the drips accumalate(sp) and drip onto the floor.
Some one has to be able to shed some light on this for me, it's driving me crazy.
I do know that it is dripping from the driveshaft onto my hanger, but how the hell is it getting onto my drive shaft?
Old Sep 19, 2006 | 10:50 AM
kreionic's Avatar
In the old 03 my t case was leaking and I need a new o ring
Old Sep 19, 2006 | 10:51 AM
revvin9k's Avatar
Where is this O ring you speak of?
Old Sep 19, 2006 | 11:41 AM
when you filled the tc was the car leveled? Or did u jack it up on the side and fill it? You may have over filled it.. What you do is, you jack it up on the side fill it up, then level the car. Once fluids starts coming out, let it flow out until its at the proper level.. If that doesnt work, then you have a leaky tc...
Old Sep 19, 2006 | 12:09 PM
revvin9k's Avatar
I did exactly what you mentioned above. In case I did have a leaky TC, where would I be looking or what would be the culprit? Thanks.
Old Sep 19, 2006 | 12:12 PM
WrX Kila's Avatar
maybe a seal?
Old Sep 19, 2006 | 12:16 PM
Sounds like you may have a bad seal or o-ring.Take it to the dealer...How bad is it leaking?
Old Sep 19, 2006 | 12:25 PM
revvin9k's Avatar
Not bad at all. Like I said, if I wipe it down and then go out for a drive, I park it and usually in a half hour you will see the fluid start to form on the lower exhaust hanger. If I let her sit over night, I have about 4 drops of fluid on the floor. There is NO WAY in hell the dealer is gonna even look at my car w/ the mods I have.
Sad to, beacuse I only have 16k miles.
Old Sep 19, 2006 | 12:41 PM
Yes but its leaking and its not like you blew the tc or anything.. Take it to AMS have them look at it
revvin9k
Jun 3, 2008 12:35 AM
revvin9k
For Sale - Cars For Sale
38
Mar 13, 2008 07:00 PM
revvin9k
Jul 8, 2007 06:07 PM
revvin9k
Aug 18, 2006 04:25 PM
revvin9k
Apr 28, 2006 02:24 PM
