Evo IX Dyno Tune Results
Old Oct 7, 2006 | 04:01 PM
  #46
housedj's Avatar
Originally Posted by Noob4life
That can't be stock ECU... what sort of dyno was this run on?
the graph says dynojet...
Old Oct 7, 2006 | 04:05 PM
  #47
housedj's Avatar
your AFR is on the lean side for pump gas. that line should be FLAT at 11.5:1 until about 5500RPM then begin to run rich towards redline.
also since Dynojets read high (AKA the Magazine Dyno...) your ACTUAL whp #'s are probably 30% LOWER than what the graph is showing.
knowing that, ur 9 is still at around 300WHP which should put you in the LOW 12 1/4mile times assuming u have a good clutch already...
Old Oct 7, 2006 | 04:14 PM
  #48
EvoTio's Avatar
The track he is racing at is at near the 3000 foot level. He will not run the same times as the guys with IX's at sea level or close to it.
Old Oct 7, 2006 | 04:29 PM
  #49
Dont Try To Run's Avatar
Holy crap man, that is incredible.
Old Oct 8, 2006 | 01:53 AM
  #50
BlueFish's Avatar
I still have a stock clutch. But I know it will not last for too long. I do manage to get mid 1.7 sec 60' times. My problem is that my 03 WRX made 282whp 230torque on the same dyno and it ran a 12.6 at 106-107mph at LACR.
manolo2011
Oct 8, 2013 03:45 PM
siakol
Jul 10, 2013 02:20 PM
Jinggyachi
Sep 15, 2012 11:06 PM
Trail Slide
Mar 25, 2009 09:38 PM
il2az
Jul 22, 2005 12:06 AM
