Greddy Type-S Flutter
Old Sep 26, 2006 | 01:00 PM
ShtrMcGavin's Avatar
I have the Greddy Type-s bov on my evo 8 running 19psi and it flutters pretty much until I accelerate again. At first it didnt bother me and I kind of got a kick out of it because I am not leaking boost or anything but the sound is driving me insane. This bov used to be on my wrx and it sounded great with a very sharp sound.
I have the adjustment screw turned almost as tight as it will go the screw is about half way inside the 10mm nut.
Anyone have any ideas?
Old Sep 26, 2006 | 01:03 PM
Smike's Avatar
Search...
http://evomoto.com/tech_info.php?tPa...0843aa78c3eba4
...and your welcome
PessimiStick's Avatar
Most people will suggest getting an IX stock/JDM MR DV.
Old Sep 26, 2006 | 01:06 PM
Smike's Avatar
Ah why? This DV, once adjusted properly, will work great. As long as its not VTA its fine.
Old Sep 26, 2006 | 01:08 PM
I don't personally have any valuable input, but every time I see threads about BOVs it seems to turn out that way. =)
Old Sep 26, 2006 | 01:11 PM
Smike's Avatar
VTA BOVs are bad (i.e. HKS SSQV). If someone is looking for a DV I recommend IX (JDM MR), APS, or a Forge. However, in this case, he already has a good one - just needs to adjust it some.
Old Sep 26, 2006 | 01:29 PM
First thank you smikeevo... Also I agree with everyone saying bov's are bad or a waste of money but I had to buy it for my wrx because at 18psi the stock was leaking and I figured why not put it on the evo and leave it recirculating
S2myEvo's Avatar
i agree! yes i am about to pick up a greddy Type S
Old Sep 26, 2006 | 01:37 PM
hamx0r's Avatar
i have a forge dv on my evo 9 and connected it to my injen intake and uicp and i love it cause you could hear it more than stock and you could hold more boost if you ever wanted to go boost crazy.
Old Sep 26, 2006 | 01:39 PM
Smike's Avatar
Anytime ShtrMcGavin
Old Sep 26, 2006 | 01:50 PM
Dapper Dan's Avatar
would you like to explain why VTA BOVs are bad? i have a ssqv that vta and ive been running it for the past year and have had zero issues with it....
Old Sep 26, 2006 | 01:56 PM
Evoryder's Avatar
sounds like you have it adjusted too tight!
I'm running both springs and have mine adjusted towards the top(looser)
Old Sep 26, 2006 | 02:36 PM
Smike's Avatar
You need to search. Im not going to rehash something that has be beaten to death. Advance search VTA and Warrtalon, MaibuJack, heck even SmikeEvo.
Old Sep 26, 2006 | 04:26 PM
FLAEVO's Avatar
There was a write up about single spring mod along time ago. take it apart at
the allen screws there are two spring in there leave the lightest one in there
I think it is the tallest. Put back together,screw should only be turned in three
turns.Mine hold boost up to 30psi.good luck. If this does not make sense
do a adv search under single spring
Old Sep 26, 2006 | 07:36 PM
pacent's Avatar
Yea, single spring mod should take care of your problem.
