Secret way to add back 30-40HP????
Old May 8, 2003 | 02:42 AM
Jonasan50's Avatar
I don't think that anyone has unbolted the turbo from the exhaust manifold just yet... So far everyone has been using the stock turbo for modding... I'll ask a friend of mine that is a head tech at Mits down here... When I find out, I'll post it back up on this thread... PROOF is the info needed!!!
Old May 8, 2003 | 06:47 AM
OX's Avatar
OX
Even if its true and gives you enough air to make an extra 30 HP, how is that going to lean it out, programming will not change. It'll still be pig rich with crappy timing.
Old May 8, 2003 | 07:16 AM
xtnct's Avatar
Having dealt with a bad turbo kit for one of my cars where the gasket was acually slightly bigger thant the manifold and turbo inlet, I can tell you that it would have burned up and blown out by now. I have blown about 5 of these gaskets on my kit until I finally returned it (this was only 1 item of the bad kit design). What happens is that the restrction creates hot spots, that evetually burn up the gasket from the inside out. So, I take this idea of a gasket being used as a restrictor with a grain of salt.
However, the mitsu gaskets could be different from the sheet metal ones that I had. It could actually be a restrictor plate that would hold up to the temps (like someone already mentioned), but it would have to be one hell of a restriction to cut out 30hp.... no? I think there are much easier and more reliable ways to cut 30hp from a car, such as running it rich.
Anyway, an investigation with a few facts to support one or the other would quickly put this urban legend to rest...
Old May 8, 2003 | 07:54 AM
eevoo's Avatar
I won't believe it until I see two dyno sheets.
1. Stock
2. After removing the gasket
Please God let it be true though!!!
Old May 8, 2003 | 08:22 AM
skibum's Avatar
I am not an expert but I play one on tv.(kidding)
Coupled with rumors of emisions trouble and lack of power on the Evolution this makes perfect sense to me. If the oriface on that gasket is small it could easily steal 30hp. We don't know how small it is. If it was small enough it could steal 271hp! Maybe the tuners know and they will sell you an exhaust for $600 claiming it alone gives the gain in power.
I can't wait find out the truth. Maybe it is all bs.
Old May 8, 2003 | 08:25 AM
Lee's Avatar
Lee
Or simply due to the fact your running on lower Octane then what we run here in Japland. IIRC as stated on the press release "specially tuned for gasoline octane numbers used in the U.S." course you know why...to conform to your emission regulations. I don't think the small gain is substantial unless it really exist!...when most of you, I assume will start dropping in 2835 or 3037S once the car is run in.
Cheers
T
Old May 8, 2003 | 08:27 AM
Fireball's Avatar
does use sheet metal gaskets, which you won't be able to blow by.
Old May 8, 2003 | 09:05 AM
fusoguy's Avatar
I fail to see how a removing a restriction in the exhaust, before the turbo, is going to increase horsepower. The boost obtained from the turbo is regulated with the waste gate, it is still going to activate at the preset boost, regardless of exhaust volume. Logically, this may actually increase turbo lag. The restriction in the exhaust's path to the turbo may actually increase the exhaust velocity, meaning the turbo may spool-up faster, remove the restriction - same volume, less velocity = longer spool-up time, more lag. I think this is a myth, but I'll try to confirm - I know the trainers that are supposedly the source for this mod - but it makes no sense to me.
Adios,
Fusoguy
Old May 8, 2003 | 09:17 AM
zyounker's Avatar
Ok, i have heard there is a restrictor from other sources.. but have not seen it..
Maybe it is time to get out the die grinder
Old May 8, 2003 | 09:19 AM
Ibiza013's Avatar
someone pull off their manifold already!!!!
Old May 8, 2003 | 09:20 AM
DRC Imports's Avatar
fireball knows the guy that im talking about. bryan, its matt. with the blue evo you saw when i rode in yours. ask your techs about this then confirm what im saying.
Old May 8, 2003 | 09:25 AM
RallyBrit's Avatar
if this is true, would the EVO still be able to pass emissions testing??
Old May 8, 2003 | 09:26 AM
cannyboy's Avatar
Would this be something along the lines of the 32mm turbo restrictor that all the wrc cars have to use. If that is the case, removing it in principle would generate that sort of HP gain.
Old May 8, 2003 | 09:34 AM
stvbreal's Avatar
Im tempeted to just take the damn thing apart myself and find out.
Old May 8, 2003 | 09:35 AM
Scot's Avatar
Yamaha puts a restritor washer inside the header of a 50cc motorcycle to prevent little kids from killing themselves too quickly... maybe Mitsu thought the same about Evo owners.
