Put on HKS Suction intake -- big problems w/ car. HELP!
Old Oct 20, 2006 | 08:45 PM
  #91
sl0ev0's Avatar
your maf is probably on backwards. i did the same thing and the car was doin the same thing
Old Oct 20, 2006 | 08:47 PM
  #92
4WS Tuning's Avatar
where in south florida are you? im in broward county... pm me if ur close and we can meet up and check it out
LAter
Old Oct 20, 2006 | 09:13 PM
  #93
r0ck3r's Avatar
I will take pics of everything in the engine bay and post them up tomorrow. I dont think I can put the maf on backwards it only connects 1 way, and the "boxy" part is on top
Old Oct 20, 2006 | 09:19 PM
  #94
Turd Squirter's Avatar
Vice grips, intakes, and STILL driving the car when it was obviously begging for mercy. Does anybody research their purchasing decisions beforehand? Until you've got people lining up at the dyno JUST to see your tuner run a baseline, then an aftermarket intake is a waste of time and money. For the same money you could have bought some mods that make a noticeable and instant improvement to the car's performance. A boost controller for example. A stiffer rear sway bar too. You also could have bought four K&N drop-in filters for the price of that intake. An ounce of prevention is worth a pound of cure. I hope you get this fixed but you've only yourself to blame. Better luck on the next mod.
Old Oct 20, 2006 | 09:21 PM
  #95
r0ck3r's Avatar
yes i researched. you know the responses i got?
"mine ran fine"
"i needed a tune after"
over and over.
no need to say its my fault cause it isnt working right. i already have a fully built mustang. i just want to put minor parts on it as of right now.
Old Oct 20, 2006 | 09:26 PM
  #96
NA cars respond very differently to specific mods than a forced induction motor. All you should be doing is letting that 4G63 "exhale" easier right now. The stock airbox provides plenty of "inhale". It sounds like you know how to wrench. You would love the extra power from a cat-back exhuast and it's easy to install with some jackstands or some rhino ramps.
Old Oct 20, 2006 | 10:15 PM
  #97
Warrtalon's Avatar
"mine ran fine"
over and over.
Look, we know that isn't what you found when you researched. We have thousands of threads saying the same thing about NOT GETTING AN INTAKE. Over and over and over to the point of insanity.
Old Oct 20, 2006 | 11:18 PM
  #98
r0ck3r's Avatar
Dude, I'm not gonna argue. I made my own post about intakes and listening to what some people said before I made up my mind. Why are you so gung-ho on the fact that im a newb when it comes to cars? my god.
Old Oct 20, 2006 | 11:37 PM
  #99
RoadSpike's Avatar
I think whats bothering warrtalon the most is that it hurts your performance at this moment and your still bent on using it.
On topic:
Alot of posters have pointed out that an air leak or misplaced vacume hose would cause very similar results. I'd like to add that a vacume leak could do similiar behavior.
You don't happen to have a vacume/boost gauge do you? would be kinda usefull to check if your idle vac. is alright.
Old Oct 20, 2006 | 11:41 PM
  #100
Jimithing60089's Avatar
Ditto, my car ran fine after getting the same intake as you installed, not sure what is goin on.
Old Oct 21, 2006 | 12:05 AM
  #101
eponti's Avatar
best thing to do is put ur stock filterbox back on then go from there
Old Oct 21, 2006 | 06:28 AM
  #102
oldscholevo's Avatar
and i was just going to remove the filter and see how it ran at idle
yes this is the correct way to check the problem. please don't warry about what other people said. i am 100% behind you.
Old Oct 21, 2006 | 07:16 AM
  #103
xcuzme's Avatar
just put this intake on my car today
car runs fine
car idles fine
my guess, you have the maf sensor on back to front. make sure your maf loom is facing the front of the car. if it isnt, its on the wrong way.
Old Oct 21, 2006 | 07:35 AM
  #104
gsrboi80's Avatar
Originally Posted by DSMEVOLUTION
Man I'm so suprised 99% of you guys talk out of you butt hole. Putting an intake on does require a tune but that will not make his idle f_____p up. Do some research before posting.... please!!!! You must have hooked something up wrong. Try throwing the stock air box back on and see if it still does it. You can drive around all you want with an intake on without a tune but you'll lose power and it would be a good idea not to get on it at all.
+1
Old Oct 21, 2006 | 09:50 AM
  #105
Ryan Bell's Avatar
....uh, yeah that sounds good. Try that one, and let us know.
Seriously though, the previous posts are right. You should be concentrating more on the exhale than the inhale. Once you get TBE, etc, THEN put cold air on and get a tune for all of it.
