Most Accurate Boost Gauge on the Market.
Old Oct 31, 2006 | 09:12 AM
  #91
Soon2BEVO's Avatar
VDO is great, had them in my DSM too! $29 and was more accurate that $100+ Defi's.. go figure lol
Old Oct 31, 2006 | 09:21 AM
  #92
TURBevO8's Avatar
Well speaking from experience my Defi BF amber Imperial boost is off 2psi. I still think it was worth the money for me because I do use my peak hold and play back and above all I paid for them to match the factory guages. I mean if I had a cheap 1st gen DSM I wouldnt care how it looks but after dropping 30 grand on a car I want it to look perfect, not just work well. The Stewart Warner's look the same at night but have white numbers by day. They are more accurate and cost 1/4 as much. This seems to be what some of the big name guys are using like Dave Buschur and Al Freidman. If I could do it all over I would still get the Defis based on looks alone but if you dont care about that, then go Steward Warner. Period. Just my 2 cents....
Old Oct 31, 2006 | 09:23 AM
  #93
Boost4me's Avatar
AEM Tru Boost Gauge and controller seems to be right on, ayone quote me on that ?????
Old Oct 31, 2006 | 09:32 AM
  #94
FiftyFive's Avatar
No one has commented on the Apex gauge, is it that noone really uses it or is it just inaccurate?
Old Oct 31, 2006 | 10:03 AM
  #95
6-speed's Avatar
Originally Posted by hondafan
the greddy 60mm has a peak hold/warning function.
I was looking at the Greddys prior to purchasing the Defis but unfortunately they do not offer gauges that read in SI units.
Old Oct 31, 2006 | 10:09 AM
  #96
Grog's Avatar
I used an Apex'i 60mm mechanical boost gauge in my Eclipse. Don't know exactly how accurate it was, but it gave nearly identical boost readouts to my HKS EVC boost controller (after changing between units). I set my boost controller for 1.25 bar and the gauge read 18 psi on the nose all the way to redline.
This was the old EL-series, not the new(er) EL2's with playback. The gauge is pretty cheap, but not as cheap as the Stewart Warner's. The only advantage I can see over the Stewart Warner's is the fact that it's 60mm (SW's are all 52mm).
They aren't that popular for Evo's, but I think most of that is the bright blue backlighting that doesn't match the Evo interior lighting.
Old Oct 31, 2006 | 01:29 PM
  #97
hondafan's Avatar
they do now. i know this for a fact since i have a 30 psi greddy gauge in my car right now. if i knew how to post pics i would.
*edit*just wanted to let everyone know, the 52mm greddy boost gauges are available in 30 psi or 2.0 bar, the peak hold/warning 60mm gauges are only offered in bar. hope this clears it up.
52mm
60mm peak hold/warning
Old Oct 31, 2006 | 01:45 PM
  #98
BURNALL_4's Avatar
Originally Posted by ak47po
Defi.
defi guages read high.....i won't put anything but autometer in my cars!!!
Old Oct 31, 2006 | 02:44 PM
  #99
_EVOlved_'s Avatar
Now im just confused
Old Oct 31, 2006 | 02:56 PM
  #100
hondafan's Avatar
it's mostly preference. everyone likes to think that their gauges are the most accurate, but the only way to know is to hook it up to an air source with a calibrated gauge and see. even two differnt gauges of the same type and brand can read differently. generally, electronic gauges with map sensors are more accurate than mechanical since they self calibrate(zero out), they usually only read wrong if the sensor is bad.
Old Oct 31, 2006 | 02:57 PM
  #101
Evol.ved's Avatar
Would not how well you install the gauge also be a factor?
Old Oct 31, 2006 | 04:19 PM
  #102
carbonraptor's Avatar
gotta love defis gauges :P
Old Oct 31, 2006 | 07:20 PM
  #103
jim1969's Avatar
these new AEM's have an LED readout to 1/10th of a psi, but i'm not too crazy about the looks.
no alarms or peak. also, no EGT. I called them about this and they have no plans to offer those feature or make an EGT gauge at this time.
Old Oct 31, 2006 | 07:28 PM
  #104
hondafan's Avatar
i thought this thread was for an accurate boost gauge?
Old Oct 31, 2006 | 07:30 PM
  #105
_EVOlved_'s Avatar
Indeed honda
