Trying to make around 300whp...
Old Nov 13, 2006 | 01:41 PM
scoob2evo's Avatar
I am planning on doing the following setup... I am wondering if you all think its, cost effective and reliable power. This will be my daily driver so I don't want to go too crazy on it. I need it to stay reliable.
03 GSR Evo
1. Downpipe
2. Cat Delete
3. O2 housing
4. Exhaust (thinking of getting JIC, opinions needed)
5. Watermeth injection (aqua mist system)
6. MBC
7. Ecu flash
8. Fuel pump
What do you all think?
Old Nov 13, 2006 | 01:44 PM
EVO8904's Avatar
get a custom tune also...
Old Nov 13, 2006 | 01:46 PM
mrdevo's Avatar
With those mods, i would say 320-330 on a dynojet. If u are really worried about it being reliable, i would go with a set of cams instead of the w/m injection. Even a tuned intake can make good power if u are on a budget.
Old Nov 13, 2006 | 01:47 PM
RoadSpike's Avatar
Skip the meth injection for now and go with cams. Cams don't run out of fuel.
Also not in your list.
Tactrix Cable - About $90
Evoscan - $25
EcuFlash - $0
Custom Flash - $50+ (fun and effective)
Old Nov 13, 2006 | 01:48 PM
19psi's Avatar
might wanna put a fuel pump to be safe.
Old Nov 13, 2006 | 01:49 PM
scoob2evo's Avatar
oops forgot to add that. Thanks
Old Nov 13, 2006 | 01:51 PM
scoob2evo's Avatar
I was told cams would rob serious gas milage... thoughts?
I don't want anything supper aggressive... I was thinking hks 272's
I am coming from the Subaru world where cams don't do all that much
Thanks for the heads up, keep them coming
kreionic's Avatar
Originally Posted by 19psi
might wanna put a fuel pump so be safe.
Definatly put the fuel pump on your list
Old Nov 13, 2006 | 01:53 PM
scoob2evo's Avatar
Evoscan - $25
EcuFlash - $0
What exactly is a Tactrix Cable?
Old Nov 13, 2006 | 01:54 PM
RoadSpike's Avatar
Look at the staged upgrades from our various tuners too. It will save you some money and time getting the parts. Plus most will have a power rating on their site per package.
Staged upgrade vendors: (that i know of so far)
- AMS
- Buschur
- Gruppe-s
- TTP
scoob2evo's Avatar
will do, will do
Old Nov 13, 2006 | 01:55 PM
Smike's Avatar
03 GSR Evo
1. Downpipe
2. Cat Delete
3. O2 housing
6. MBC
7. Ecu flash
1, 2, 3, 4, 6, 7 are ok.
5, if this is a D/D I wouldnt use meth. If I was going to use meth, I would get head studs.
8. Fuel Pump
Get whatever parts you have the money for. In the end its your cash. If you like JIC get JIC, if you like BR, get BR.
You have an 03. Why not a 10.5 hotside? I would also replace that plastic DV with a IX metal DV. And get a boost gauge.
Old Nov 13, 2006 | 01:59 PM
zeus1's Avatar
here is what i made..close to 300 05 gsr
https://www.evolutionm.net/forums/sh...d.php?t=234522
Old Nov 13, 2006 | 02:00 PM
Evoryder's Avatar
cams first w/ tune + fp and other goodies!
Old Nov 13, 2006 | 02:13 PM
scoob2evo's Avatar
do the cams drastically reduse the gas milage? Even on freeway drives an such? What cams do you all suggest?
