70K - Still smart to do a turbo upgrade?
Old Dec 7, 2006 | 01:16 PM
NYREDEVO's Avatar
Ok heres a question for you guys (Posted in another thread but figured it would be worth it's own)
Would u guys jump from a stage 2 to a 4 with the and larger turbo on a ride with 70K on it? (I drive alot I know) If yea, what would you recommend as a "freshen up" things to go along with it. Basically I wanna keep this car for a long time and wanna make sure the extra power isn't going to kill the motor in the long run. Any thoughts??
Old Dec 7, 2006 | 02:08 PM
Kayaalp's Avatar
I would do a compression test on the engine before going any further. If it's not burning any oil and it makes good (and even) compression across all 4 cylinders, that's a pretty good sign the bottom end is in solid shape.
I'd be inclined to pop off the head and install a new head gasket (either OEM or upgraded) and ARP head studs. And I'd be inclined to replace the fuel injectors, fuel pump, fuel filter, and spark plugs. With a bigger turbo, you'll probably need more fuel anyway. I would also check the ignition wires to make sure they're in good shape.
If all that checks out, I wouldn't worry too much about it.
Emre
Old Dec 7, 2006 | 05:08 PM
signalauto27's Avatar
DO IT! but, take the opportunity to replace the wear and tear parts.
Old Dec 7, 2006 | 05:10 PM
gsrboi80's Avatar
All the more reason if it blows up rebuild it man
Old Dec 7, 2006 | 05:51 PM
sonicnofadz's Avatar
Wtf is a stage 2 & 4? Anyways as long as your engine is making decent compression it should be fine. You might want to just tear it apart and put new rods + pistons + bearings in just to feel safe, but its entirely up to you and your wallet.
Old Dec 7, 2006 | 05:52 PM
mrcox's Avatar
I have 96k on the clock and put down 508awhp everyday that I drive it.
Old Dec 7, 2006 | 05:53 PM
MSTR MR9's Avatar
if you have the moeny i dont see y not some times bigger is better
Old Dec 7, 2006 | 05:54 PM
NoisyTurbo's Avatar
Do a compression test and if all the cylinders check out fine, go nuts and have fun.
JaMRxHanzoxOZ
Lancer Engine Tech
Jan 10, 2014 05:42 AM
Turbo01s2k
Feb 19, 2010 10:18 AM
Nomad4g63
Jan 11, 2010 11:02 AM
dangelo2jz
10
Jan 27, 2007 04:27 PM
tacoman_3d
Apr 25, 2003 05:53 PM
