question to those with dual port BOV
Old Dec 13, 2006 | 03:09 PM
evilution8's Avatar
whats up guys im going from forge evo BOV to APS dual port adjustable. wondering whats a good setting. i have stock boost for now, only mod is full exhaust with a hallman MBC coming soon. i just dont want any stalling or idling issues. i figure if i leave it about 50/50 recirc to vent or even 70/30 recirc to vent it should be good??? to those with APS or turbosmart dual port let me know how you roll and was it a pain to adjust and figure it out.
Old Dec 13, 2006 | 03:13 PM
RallySport Direct's Avatar
Silver Sponsor
The APS one is easy to adjust. Is isn't a standard 50/50 valve since the ports are offset. It will recirc more under lower boost and recirc less and VTA more under high boost.
We tell customers to leave it at the stock setting it is the best for 98% of people. When you start running really high boost levels you may need to tighten it down a little bit.
Old Dec 13, 2006 | 03:29 PM
evilution8's Avatar
thanks rallysport i suppose ill leave it how it is then. im not planning on running higher boost soon, probably never. im just gonna get the hallman to make sure i peg stock boost haha. thanks again, im looking forward to the valve.
Old Dec 26, 2006 | 11:35 PM
evo_shibby's Avatar
what effects are there if you adjust the aps bov?
Old Dec 27, 2006 | 08:45 AM
Silver Sponsor
If you loosen the valve it will hold less boost and will allow more air out of the external port
If you tighten it the vale will hold more boost and will allow less air out of the external port
Old Dec 27, 2006 | 10:31 AM
saiyanzzrage's Avatar
im running 28 - 29 psi and left it at the stock position
Vivid Racing
12
Jul 30, 2014 03:40 PM
lookitznite
Jan 6, 2013 07:18 AM
dvd_mi
16
Nov 19, 2009 05:27 PM
Green_Bandit
Lancer Aftermarket Forced Induction Tech
Aug 1, 2008 03:35 PM
aboh6leenz
Aug 2, 2005 12:44 PM
