Need info on gaskets for install
Old Dec 13, 2006 | 06:03 PM
geevolution's Avatar
I'll be installing my cams, studs, fuel pump, exhaust manifold, o2 housing, and tme turbo soon, needed to know what gaskets I may need. Exhaust manifold, valve cover, donut from dp to o2 housing, did i miss anything? Thanks in advance
Old Dec 13, 2006 | 07:12 PM
bump...anyone?
Old Dec 13, 2006 | 08:27 PM
EvilEvo8GSR's Avatar
you got everything pretty much down.... just remember the turbo to the manifold has a gasget as well, besides the manifold to the head.
Old Dec 13, 2006 | 08:38 PM
ries's Avatar
You shouldnt need to replace any of the gaskets when you do any of these installs unless your pulling the head off the motor
1. donut gasket o2 housing to dp is reusable just dont gouge the **** out it when taking it off
2. OEM gasket between O2 housing & hotside is metal sojust dont bend or break it
3. OEM gaskets (theres 2) between mani and engine block are also metal so dont bend or break them
4. valve cover gasket is rubber so dont tear it and you can reuse it
I guess it doesnt hurt to buy all new gaskets but I didnt replace any on my car and I know a 1/2 dozen other local evos that Ive helped work on that reused the stock gaskets all w/ no problems
just a suggestion to try to save you a little money
Old Dec 13, 2006 | 08:42 PM
Heres the list I managed to put together using the parts # list
Exhaust manifold to turbo gasket
Lower Ic pipe to turbo gasket
Exhaust manifold (manifold to head) gasket
o2 housing to downpipe donut gasket
valve cover gasket
metal gasket between turbo and o2 housing
oil drain tube to turbo gasket
also someone mentioned i should change the copper crush washer on the oil feed line to the turbo, any idea if this is anything i listed above?
Old Dec 13, 2006 | 09:59 PM
anyone?
Old Dec 14, 2006 | 06:38 AM
morning bump
Old Dec 15, 2006 | 01:48 PM
Bump need help still
Old Dec 15, 2006 | 02:52 PM
no one knows?
Old Dec 15, 2006 | 05:59 PM
bump anyone?
Old Dec 15, 2006 | 09:59 PM
someone has to know
WarmPepsi
Feb 17, 2016 04:04 AM
Blizzackk
Sep 21, 2008 10:13 AM
QwikEVO
Nov 3, 2006 06:04 PM
ries
Aug 22, 2006 06:07 AM
SoR
10
Sep 22, 2005 04:13 PM
