Vibration issues
Old Dec 19, 2006 | 07:01 AM
spudlus's Avatar
Vibration issues
Hey Guys:
I have a slight but constant vibration as I drive nowadays which seems to have started a while now but is getting worse. It appears to affect the entire car and gets worse the faster I go. It's not the tires as they are balanced properly. It appears to be drivetrain related. When decelerating the vibration seems to be concentrated at the front of the car as indicated by a rattling noise, however, while accelerating there is no rattling just a slight vibrating which even the passengers can feel. If while decelerating I depress the clutch the vibration\rattling immediately stops. I don't think it's the throw-out bearing as it not only rattles but vibrates. At 90MPH it's unbearable.
Any ideas or thoughts?
Thanks!
Old Dec 20, 2006 | 05:10 AM
spudlus's Avatar
No ideas?
Old Dec 20, 2006 | 05:29 AM
gsrboi80's Avatar
Check for slop in your drive shaft, front axles, rear axles. That could be your problem for sure. Jump under there and pull the shafts up and down you shouldnt see ant play if you do there you go
Old Dec 20, 2006 | 05:55 AM
PVD04's Avatar
Is there any vibration when you rev the engine while sitting still? If the vibration goes away when you press the clutch it is probably not a driveshaft or axle problem. I would try revving the engine with the clutch engaged and with it disengaged and see if it vibrates in either of those scenarios. That could narrow it down to the engine or the clutch.
-Paul
Old Dec 20, 2006 | 06:08 AM
gsrboi80's Avatar
-Paul
Agreed I didnt read his push in the clutch part.
Old Dec 20, 2006 | 06:55 AM
CDO's Avatar
CDO
I know you said it's not the wheels out of balance, but you said the faster you go the worse it gets. After they were balanced was there a period of time before you got your car out on the highway to notice it maybe?
I bought new tires for my wife's car and took it home, no problems (city streets). She went somewhere in it (on the highway) and came back complaining of a vibration. I took it out on the highway and she was right.
I went back to the tire place and they discovered the wheel balancing machine was out of whack. Every wheel was out of balance.
If you can't find the cause elsewhere have your wheels balanced again.
Old Dec 20, 2006 | 07:14 AM
8urv8's Avatar
Could be any of these things. Just take time to check them all. Cold be something in the drivetrain. The bearings went in the u-joint at the rear diff in my truck and it would vibrate the whole truck, but I could def tell it was coming from the rear. The faster I went the worse it got because the drive shaft would stay lined up with the rear diff. If is something to do with a driveshaft, or a joint, I would get it checked out soon. You don't want to do any more damage. I drove the truck for a while before I actually took time to check out the situation, and the joint was so bad I was suprised it didn't fail completely.
Old Dec 20, 2006 | 07:17 AM
Dumb_Dog's Avatar
+1, it really sounds like the wheel is out of balance, or may be out of round? how's your tire, is it still in good shape, or tread almost gone? also check your wheels to make sure they are straight too, did you ht a pot hole lately?
Old Dec 20, 2006 | 07:47 AM
PVD04's Avatar
Wheels don't balance themselves when you push in your clutch. If the vibration really goes away completely when you push the clutch in, then it is most likely either the clutch or the engine.
-Paul
Old Dec 20, 2006 | 08:21 AM
Vivid Racing's Avatar
Do you have a aftermarket clutch? If so do you trust your installer? I have seen it where a bolt or two break on the flywheel or pressure plate, causing this vibration.
Best of luck!
Old Dec 20, 2006 | 10:51 AM
CDO's Avatar
CDO
-Paul
I guess I didn't catch that part of his statement.
Dross99_si
13
Sep 16, 2016 10:57 PM
Ryley
Sep 5, 2015 02:50 PM
TommiM
15
Sep 30, 2014 04:46 PM
crpearce
Oct 3, 2010 09:10 PM
troe666
10
Sep 5, 2006 01:01 AM
