Smoke during acceleration
Old May 25, 2003 | 03:37 AM
SilverEvo8owner's Avatar
Today i took my evo above 5k and i noticed that there was smoke coming out of the the exhaust above 5k with WOT
I reall y cant see it during the day but i cant see it in the headlight of cars behind me
My brother was following me home today and he said that he cool smell it through the a/c
He could only describe it as smelling like exhaust
He said i could see the smoke in the headlights also
Does anybody else have this?
Its only during WOT
Old May 25, 2003 | 06:43 AM
2Cool's Avatar
Its unburnt fuel, caused by the ECU running the car very rich at high RPM. Its safe and not a problem, but too safe for real power...
Old May 25, 2003 | 10:05 AM
Dgenx97's Avatar
Noob here so fogive me if this sounds dumb, but if we reset the ECU would that do anything to fix the cary from running so rich?
Old May 25, 2003 | 01:25 PM
no it wont
Old May 25, 2003 | 01:36 PM
the evo wins's Avatar
the evo ecu is ****ed up i want a ecu upgrade lol
Old May 25, 2003 | 03:23 PM
chan816's Avatar
hahhaaa...
^_^
Old May 25, 2003 | 04:03 PM
3K's Avatar
3K
Your're running too rich. How's your idle is it rough?
Old May 25, 2003 | 05:26 PM
Dubai_EvoVII's Avatar
When I read the subject " Smoke during acceleration " First thing came to my mind that you are very hard on the clutch that it smokes every time you accelerate heheheh....
But that's not the story.. Well as the guys said it is from the unburn fuel .. when the car is on high RPM it runs rich and that is good to keep the engine safe if you are running a little bit more boost.
Old May 25, 2003 | 05:58 PM
sometimes my idle is rough
it gets rough when the a/c is on (2.0l engine) but every once in a while it will get rough for a couple seconds and then will idle fine
whenever i fill up with gas it gets rough also
my evo is completely stock, i dont have an S-AFC or boost controller
Old May 25, 2003 | 08:25 PM
shirokuma's Avatar
All the JDM cars, when stock, do this under heavy acceleration. Manufacturers tend be very conservative around high-strung 2.0-litre turbo's when it comes to keeping the motor in one piece for a relatively long amount of time, and running it rich is one of the methods used.
Cheers,
Paul Hansen
Old May 25, 2003 | 08:54 PM
Hanzo's Avatar
My car does the samething, I think it could be the way the USDM ECU is tunned.
Old May 26, 2003 | 05:50 PM
jfh's Avatar
jfh
Like 2Cool and Paul Hansen (by the way Paul nice to see you over here) said it's due to extremely rich A/F mixture mapped for safety purposes.
Also the reason it is sooo easy to make more power by properly enleaning the mix with an SAFC or XEDE. Really need a wideband O2 sensor to do it right. That's how get rid of the flat line performance usually encountered above 4500-5000 RPM and make it keep pulling in a linear fashion all the way to red-line.
It's like driving a totaly different car.
eisnikesb
Jul 20, 2014 04:38 AM
Dave221982
Oct 17, 2012 10:18 PM
evotuner1021
14
Oct 9, 2012 08:43 PM
tazdevilxxi
15
Aug 26, 2011 07:25 AM
06FQ360
Jan 5, 2008 01:45 PM
