constant white smoke when idling
Old Jul 18, 2014 | 05:31 AM
eisnikesb's Avatar
So yesterday I went to a reputable shop and had my car looked at for a constant white smoke coming from the exhaust when idling and is very noticeable on hard acceleration. They said it could either be the head gasket or the valve seals on the exhaust side. Also when you smell the smoke it doesn't smell sweet like it would be coolant. Does this sound right or should I try something else first. Thak you in advance for your help.
Old Jul 18, 2014 | 05:35 AM
oneonlywgs's Avatar
If you a smoking like a choo-choo, something happened. Until the engine is taken apart, they will not know the exact problem.
Old Jul 18, 2014 | 05:45 AM
MR. EVO MR's Avatar
Sounds like you blew your head.
Did you overheat recently??
If you take the head off, do some drop in pistons and rods.
GL!
Old Jul 18, 2014 | 07:24 AM
Ev0ikon's Avatar
Before you do anything else, clean out the PCV valve. Then report back.
Old Jul 18, 2014 | 07:57 AM
eisnikesb's Avatar
They did compression and leak down test they said everything was perfect and I was wondering if it could be running leaning because I just up a new evo 8 turbo in a little while back and it seemed to do it right after I did that as well as loose peak boost pressure
Old Jul 18, 2014 | 11:54 AM
RalliFast's Avatar
White smoke is a pretty clear sign of a lean mixture especially considering it doesn't smell sweet and you've done a compression test... I take it you don't have an air/fuel ratio gauge, you should consider investing.
Old Jul 18, 2014 | 11:56 AM
twabtoxer's Avatar
Nawss! !
Old Jul 18, 2014 | 11:59 AM
Gstv's Avatar
This i had the same problem at first i thought it was the turbo seal that went bad and after we checked the engine after all that and spending a bit over $1k to diagnose and not find anything i decided to trade it in for a new evo the dealer ended up cleaning the pcv valve and problem went away, i wish i knew about the pcv back then
Old Jul 18, 2014 | 12:04 PM
NSDQ's Avatar
damn, kinda like having your dream woman and then thinking she's cheating on you and spending all kinds of time and money on a PI and trying to catch her and you don't/can't but you say screw it and divorcing her anyways and then get a new girl only to suddenly learn she was never cheating on you but now you can't get her back. haha
Old Jul 18, 2014 | 02:18 PM
eisnikesb's Avatar
So clean the pcv first then look into tuning then if that still doesn't work then pull the head
Old Jul 20, 2014 | 04:38 AM
wowzers's Avatar
Yeh check PVC valve…
hows the Coolant Reservoir? Do you lose any coolant?
Firstly, check if the coolant has any oily residue.
Use a rag to undo the radiator cap when the engine is warm… see if any small bubbles emerge… that can indicate a head gasket.
AZRALLIART
14
Feb 20, 2016 07:48 PM
GgreyEVOIX
Nov 8, 2012 01:04 PM
R. Burgundy
Aug 15, 2012 09:35 PM
THE8UH8
Oct 22, 2011 10:18 AM
ramievo7
12
Jan 30, 2011 11:37 AM
