GM Maf Sensor
Old Jan 17, 2007 | 05:06 PM
WrX Kila's Avatar
GM Maf Sensor
Wanted to know.. how many people here running them? What are the advantages of getting one? If I decided to get one , would I need to get the car retuned? I contacted Mike at Full Throttle and he told me that the GM sensor is better than the stock one. I have a flash and making about 500+ whp with a gt35r. Thanks in advance for inputs.
Old Jan 18, 2007 | 06:01 AM
WrX Kila's Avatar
10 views no response!!
Old Jan 18, 2007 | 06:11 AM
ThEHiTMaN's Avatar
I am thinking about the same thing.... Sounds very interesting. What all is necessary for the conversion?
Old Jan 18, 2007 | 06:14 AM
MRadjahoe's Avatar
All you need is the GM MAF and the converter I belief! Somebody correct me if im wrong.
Old Jan 18, 2007 | 08:39 AM
Ev0cRaZy's Avatar
Im running one on my 37r setup....It will not work with the SAFCII, I found that out the hard way. Get a Translator and GM sensor and its real easy to install, you just need to learn how to adjust the knobs on the translator. Be sure to have a wideband. It runs a lot better with the GM sensor than the Stock MAF, you will tell a big difference. PM me if u have any ?'s
Old Jan 18, 2007 | 09:58 AM
RoadSpike's Avatar
Look for Malibu Jack's posts on the MaftPro unit, that man has his stuff down on the MAF conversions and the advantages and the disadvantages of the blow through and pull through setups.
Old Jan 18, 2007 | 10:03 AM
TogueMonster's Avatar
I was just looking into that last night. Came up with this...
http://evo.dejonpowerhouse.com/
click on fuel/electronics
Old Jan 18, 2007 | 10:04 AM
Nez136's Avatar
Also look in the sub forums of the ECU+ egine managment, i think there are a decent amount of people running maf trans. Dryad is running a flash with Dejon's maftrans kit and seems to be very happy with it. A base flash is usually the best way to go so you can scale your injectors without having to futs with it on the maftranslator
Old Jan 19, 2007 | 05:04 AM
Ev0cRaZy's Avatar
Yeah, im friend with Mike aka: Dryad001.....We both are running the MAF Translator with 3in GM sensor, just IM me on AOL at Zachb01, ill be happy to help and im sure mike will also.
foxbat
Jul 17, 2014 09:29 PM
arpad
Oct 1, 2013 01:58 PM
CtSilver03Evo
Jun 27, 2012 08:56 AM
GGP Wolf
Dec 12, 2007 02:43 PM
travman
Aug 24, 2007 05:32 PM
