Engine Warm-up???
Old Jan 22, 2007 | 11:13 AM
  #61
boostinjuice's Avatar
start the car.. let it heat for a minute.. and gooo... then after a couple minutes.. your good to go
Old Jan 22, 2007 | 11:57 AM
  #62
number 8's Avatar
I always wait til the temp gauge needle starts to move. Trying to drive the evo when its still cold sucks. It bucks and heaves like a rodeo bull.
Old Jan 22, 2007 | 12:01 PM
  #63
EvilEVO800hp's Avatar
good stuff to know for the future, THANX
Old Jan 22, 2007 | 12:03 PM
  #64
EVO8emUp's Avatar
Speaking of warming up pertty fast... the heaters in these things are nothing like the old DSM heaters. Those things had blast furnaces!
"I always wait til the temp gauge needle starts to move. Trying to drive the evo when its still cold sucks. It bucks and heaves like a rodeo bull."
Number 8 -- I was wondering if it was just mine that did that. Wonder if it has to do with the car being in open loop until it warms up?
Old Jan 22, 2007 | 12:09 PM
  #65
sonicnofadz's Avatar
Letting the engine warm up is *VERY* important for a forced induction motor. The oil, bearings, and rings all need to be near operating temperature before driving the vehicle in order to prevent premature wear.
Old Jan 22, 2007 | 12:12 PM
  #66
Vidulea's Avatar
Mine does that too! I guess it doesn't really like it when it's cold. The guys from Road and Track complained about that after the 50K test!
Old Jan 22, 2007 | 12:29 PM
  #67
Robevo RS's Avatar
yes because the evo is running very rich from factory+ more rich /extra gas/ when is cold...
that is why i wait untill my rpm drops to 1000 or below.
Old Jan 22, 2007 | 01:13 PM
  #68
evoixbri's Avatar
i warm my car up for 12 minutes because of my remote start turbo timer.
Old Jan 22, 2007 | 01:14 PM
  #69
evoixbri's Avatar
Wouldn't you rather have your car warmed up fully then barely warm? I like to drive my car when the tranny isn't notchy yet nice and smooth.
Old Jan 22, 2007 | 01:15 PM
  #70
evoixbri's Avatar
How is warming up the car over 10 minutes bad for the evo?
Old Jan 22, 2007 | 01:26 PM
  #71
Warrtalon's Avatar
Negative. Did you not read the entire thread? It's important to get the engine warmed up before BOOSTING, not before driving it. YOu are supposed to warm it up BY DRIVING but not boosting or revving hard. You do not warm the car up by idling...
Old Jan 22, 2007 | 01:28 PM
  #72
Warrtalon's Avatar
10 mins is ridiculous, and warming it up by idling does not warm up the transmission anyway. YOu need to drive the car to warm it up - same goes for the trans - just double clutch that first 1-2 shift, and the rest is fine. Also, if you have a cat, idling for extended periods of time can damage it.
Old Jan 22, 2007 | 01:31 PM
  #73
Yes, the entire thread is WRONG. You can drive the car before it is fully warmed up (don't boost it) however this will cause pre-mature bearing failure. Not boosting helps saving the rings, but there is MORE TO AN ENGINE than the piston rings. When you drive the car cold and without boost, the bearings and oil are still cold, causing improper oil flow, and wear to the bearings (if the bearings are still cold they haven't expanded to their operational size and will cause the rod to knock around until they expand).
Old Jan 22, 2007 | 01:33 PM
  #74
Wrong again, letting the engine warm up idling at a standstill WILL warm the transmission up a little. When the clutch is engaged, and the transmission is in neutral, there are many shafts that are rotating INSIDE the transmission, however there is no load on them, but the friction of this rotation causes HEAT. Go read how a transmission works. Better yet, go rebuild one and then think about why I said this.
Old Jan 22, 2007 | 01:34 PM
  #75
Warrtalon's Avatar
Negative.
Idling Myths:
Myth #1: "The engine should be warmed up for long periods prior to driving."
Reality: Idling is not an effective way to warm up your engine, even in cold weather. The best way to do this is to drive the vehicle. With today's modern engines, you need no more than 30 seconds of idling on winter days before starting to drive.
Myth #2: "Idling is good for the engine."
Reality: Excessive idling can actually damage engine components, including cylinders, spark plugs, and the exhaust system.
Myth #3: "Shutting off and restarting the vehicle when it's stopped is bad for the engine and uses more gasoline than if you leave it running."
Reality: Frequent restarting has little impact on engine components. Component wear caused by restarting the engine is estimated to add $10 per year to the cost of driving, money that will likely be recovered several times over in fuel savings from reduced idling.
Idling Facts:
Fact #1: Idling wastes fuel and money. Every 10 minutes of idling costs you at least 1/10 of a liter of wasted fuel. Keep in mind that every liter of gasoline produces 5.4 pounds of carbon dioxide.
Fact #2: Idling contributes to global warming. Vehicle idling can have a powerful effect on the outdoor air quality at the local and community level.
Fact #3: Diesel and gasoline exhausts contain more than 40 hazardous pollutants. Idling your vehicle with the air conditioner on can increase emissions by 13 percent.
