Push Button Ignition method....
Old Feb 3, 2007 | 10:10 PM
jasburbak's Avatar
I'm trying to understand what you meant by getting around the immobilizer, with this system i just said, you wouldnt have to bypass the immobilizer, right? because the key is being used. The wiring sounds simple enough, although if i cant figure out from the instructions, i'll have a friend who does electrical work help me.... Thanks for the help guys...
Old Feb 3, 2007 | 10:20 PM
SophieSleeps's Avatar
If you want to forego inserting the key, you'll need an immobilizer bypass. They cost about 20 bucks.
Otherwise, if you use the key you'll be fine.
Wiring this up is very very simple.
There is a starter wire.
There are 2 scenarios:
No more starting with the key:
You can cut the starter wire and send the car-side wire to your switch. Splice into the constant wire and send that to your switch. When you push the switch/button it closes the connection and the constant and the starter wire.
Start as normal as well as with the starter button.
Follow the same procedure but do not "cut" the factory starter wire. Simply splice into it.
Old Feb 6, 2007 | 09:40 AM
kmcconn9's Avatar
I would just install a remote start and call it a day...
Old Feb 6, 2007 | 10:16 AM
CaymanEvo3's Avatar
Originally Posted by RenEvoIX
hmmm thats pretty good.. but how did u do it when u take the car to the delar & say you wanner do an oil change .. I do not want other ppl to know how I start the car...
If you don't know how to change your oil your a retard or just a lazy rich person.
Ancyker
22
Apr 4, 2016 04:58 PM
RA012124
Outlander Sport
Jul 26, 2014 11:55 AM
evo_soul
Toronto Lancer Club
27
Sep 5, 2012 07:26 PM
frhstrack11
19
Feb 14, 2008 07:51 PM
CatalystIX
Feb 12, 2008 06:53 PM
