Zeitronix Help
Old Feb 11, 2007 | 01:20 PM
JeffMas1587's Avatar
Zeitronix Help
Ok so i have a zeitronix wb with egt and boost. the display screen is hooked up and working just fine. but when i hook my computer up i cannot connect. i dont have a serial port on my computer so i went to best buy and got an adapter to change it to usb. i have tried com ports 1-8 and none of them with my 6 usb ports. yes i tried 48 different times. any advice. i have a dell xps laptop
Old Feb 11, 2007 | 01:45 PM
steevo's Avatar
The only serial port adapters I trust are from Socketcom. They are expensive, but they work the best. I recommend the PC Card Serial Adapter. Here's the link:
http://www.socketcom.com/product/con...SL0700-004.asp
It will work, most of those cheap USB dont. Only use Com1-Com4.
Old Feb 11, 2007 | 01:58 PM
i got one from best buy. do you know of a store i can get one from? like comp usa?
Old Feb 11, 2007 | 03:05 PM
steevo's Avatar
Order it from there site. I have never seen one in a retail store. Here's the link to buy: $149!! http://www.socketstore.com/product.asp?sku=1020653
Old Feb 11, 2007 | 03:09 PM
there has to be anther way then spending 150.
Old Feb 11, 2007 | 05:37 PM
Zeitronix's Avatar
JeffMas
Some USB adapters work better than others. One we stock works well.
Check in the device manager what virtual COM port is your USB adapter assigned to. Some USB adapters install at high COM numbers (above 8).
Also, please make sure you are using the original serial plug and phone like wire supplied with the Zt-2.
Thanks
Zeitronix Eng.
Old Feb 11, 2007 | 05:49 PM
i have everything original. i got a best buy brand serial to usb adapter. they all say pci bus 0
Old Feb 11, 2007 | 06:06 PM
Zeitronix's Avatar
Old Feb 11, 2007 | 06:11 PM
cij911's Avatar
I tested a Serial to USB converter from Radio Shack ($35.99) and it worked fine.
Go to Start ...Settings...Control Panel ... Select System...Select / click on the Hardware tab...Click on the Device Manager Button...Scroll down to Ports and Click on the +....Look and see what ports you are using (your converter will be one of those)...
Old Feb 11, 2007 | 06:13 PM
sandm's Avatar
bought mine off ebay for $9. it's something like dynex. did not come with any drivers, but works great...
here's the link to the auction I won..
http://cgi.ebay.com/ws/eBayISAPI.dll...m=140075156175
Old Feb 11, 2007 | 06:19 PM
that is the exact cable i have
Old Feb 11, 2007 | 06:28 PM
wrcwannabe's Avatar
That screen says the device is not configured correctly. Did you install the driver ? Did something go wrong in the install ? Uninstall and reinstall the driver that came with the cable. See if that fixes it.
Milburn
Old Feb 11, 2007 | 06:29 PM
Zeitronix's Avatar
It's hard to see on this small pic but it looks like there is a yellow question mark there.
Did you install the driver supplied with the USB adapter?
Old Feb 11, 2007 | 06:36 PM
sorry for the small picture. ok i went the their web page and dl the driver for it. now its all set up. i will go test it out real fast and get back to you if it works
Old Feb 11, 2007 | 06:50 PM
ok great it works. com port 6.
