Defi Oil Gauges
Old Feb 13, 2007 | 10:17 AM
scoob2evo's Avatar
Defi Oil Gauges
So I just purchesed my Defi Oil pressure and Oil Temp gauges.... I have heard from a few different people that I won't be able to install them wiht the supplied hardware. Has anyone run into this? Do you all have some tips/advise for me before I start this install? I have been searching but have not been able to find a specific answer with any kind of proof. Any help would be most appreciated.
Thanks in advance guys!
Old Feb 13, 2007 | 10:22 AM
kapolani's Avatar
You have to pick up some adapters so that they can mate to the oil filter housing.
I picked up these adapters from one of our sponsors:
http://www.42draftdesigns.com/vdo.htm
If you look at the bottom of the page - there are the senders that you need.
Also - do a search for a guy named bolsen. He had a write up that was pretty good.
Old Feb 13, 2007 | 10:38 AM
scoob2evo's Avatar
what adapters did you use?
Old Feb 13, 2007 | 10:44 AM
belizelittle39439's Avatar
I bought the senders for the oil pressure, oil temp, and water temp. Should cost you a total OTD price of around $45 bucks from that site.
Old Feb 13, 2007 | 10:48 AM
scoob2evo's Avatar
Defi doesn't give you senders?
Old Feb 13, 2007 | 10:52 AM
scoob2evo's Avatar
I was figuring I needed adapters not senders
Old Feb 13, 2007 | 10:57 AM
JohnEB's Avatar
I bought my package from gruppe-s and they have a greddy adapter that goes between the block and the oil filter it worked great and was east to install try giving them a call they will know what you need.
kapolani's Avatar
Yes.
You need the adapters _NOT_ the senders. You already have them.
Look at the bottom of the page from the link.
It says Evo - you then look in your Defi manual and check if it's NPT or BPST. I can't remember off the top of my head.
Old Feb 14, 2007 | 05:48 AM
avengerhed's Avatar
the oil pressure gauge is BSPT, oil temp is NPT.
the oil pressure will thread right into the block (in the region close to your uicp - search for nils' post in bolsen's install thread) with no adapters needed. 42Draft has an adapter for the oilf filter housing.
some members have experienced problems with the sandwich adapters since the filter sits lower to the ground. some with aftermarket filters have had them get damaged/ripped off due to low clearance.
Old Feb 14, 2007 | 05:52 AM
kapolani's Avatar
the oil pressure will thread right into the block (search for nils' post in bolsen's install thread) with no adapters needed. 42Draft has an adapter for the oilf filter housing.
I don't know if I agree with the bold statement.
IIRC it is not the exact size so it may leak.
Why would you chance that rather then getting a piece that cost a few dollars?
Do it right the first time.
Old Feb 15, 2007 | 07:41 AM
avengerhed's Avatar
It does fit, perfectly. I have it threaded in my block right now, no leaks at all.
42 Draft does not make a BSPT angle adapter, I corresponded with them on this more than once.
I'm talking about a tap in the block near the UICP, down by the oil filter you will need an adapter. I edited my post above for clarity, sorry if that caused confusion.
yesevo
11
Oct 31, 2011 10:19 AM
ch1215g
11
Dec 20, 2010 01:57 PM
MPACT
Dec 1, 2008 10:00 PM
dreamevo
Sep 20, 2006 06:50 AM
alan0108
Jan 11, 2006 09:43 AM
