where does your clutch engage?
Old Feb 23, 2007 | 01:16 AM
MONSTARR's Avatar
Mine engages inside my tranny.
Old Feb 24, 2007 | 11:55 PM
Fittest's Avatar
This high clutch engagement was my immediate and first negative criticism for Evo.
Old Feb 25, 2007 | 12:01 AM
SOEuro's Avatar
sux for launching the car
Old Feb 26, 2007 | 09:01 AM
awdcomplex's Avatar
same here mine engages high/top of the stock clutch pedal...glad i found this topic
been one of my petpeeve 's with the evo
when should we start to worry that the clutch is on the way out... it terms of pedal travel...like when it travels/hooks up closer to the floor board?
Old Feb 28, 2007 | 11:57 PM
joah1660's Avatar
Yeah...mine engages at the top too. I've been told the easiest way to notice if your clutch is going out is to watch the RPM's in your top gear for slipage (if that's even a word).
Old Mar 1, 2007 | 12:28 AM
evo_rc's Avatar
before i adjusted and raise up my engagement, my act was short and i would get lock out all the time. now i took out the restrictor pill and raise up the travel it shifts alot better
Old Mar 1, 2007 | 01:08 AM
MRedition's Avatar
this pisses me off too!
I learned to drive using stick and when I got into the Evo for the test drive...I stalled once in the beggining not thinking it would catch so high....it get on my nerves as well.
One of my friends drives a Civic Si and his catches like 1 inch from the bottom, I like his more than the high catch like these Evo's
btw...is it ok to adjust the clutch catch...like said above it wears the clutch more, does it cause any other problems??
Old Mar 1, 2007 | 07:44 AM
Ph3n1x's Avatar
Mine is the same way. Top 1 inch. Its been like that for as long as I can remember. I have an 05 with close to 375TQ and its holding as good as ever
Old Mar 1, 2007 | 07:48 AM
bvdawg13's Avatar
i only have to let my clutch out about a 1/2" before it engages
Old Mar 1, 2007 | 08:19 AM
my-red-rs's Avatar
See if this helps...
http://www.evomoto.com/tech_info.php?tPath=1&tech_id=28
Watch out for the metal bracket that holds the clutch pedal safety switch!
It will slice your knucles in no time. I just bend it out of the way, adjust the clutch, and bend it back when Im done.
Old Mar 1, 2007 | 11:03 AM
binh's Avatar
you guys should adjust them but make sure there is a few mm of freeplay when you press down on the clutch....
Old Mar 1, 2007 | 04:15 PM
20lbsboost's Avatar
mine is about half way but its starting to move up and it is starting to slip pretty bad...new clutch time for me
Old Mar 1, 2007 | 04:36 PM
EVOlution561's Avatar
mine engages pretty quick, I have the ACT six puck. I would say I have to release it about less than 1/4 way for it to start to engage.
Old Mar 1, 2007 | 04:50 PM
evo8426's Avatar
so where is ideal engagement?
Old Mar 5, 2007 | 07:56 AM
joah1660's Avatar
bump...
