Anyone making big power on stock LICP?
Asking someone to back a claim with information is not attacking them by the way.
I'm sorry you don't see the point. Also, I don't need anything explained to me 5 times. You see, he made a bold statement ("I disagree, countless tuners and customers have seen consistent dyno gains") and I asked him to validate it. What's so puzzling or wrong about that?
in this case what you said was, i want to see 5 undisputable results of licps making power before i believe licps make power. why would you need 5 if the first was UNDISPUTABLE???
hence there's no point trying to explain something to someone like you becuase firstly... there's no such thing as undisputable... and secondly if there were you'd find a way to dispute it.
stock licp has more bends & is longer. That is a restriction ANY way you look at it.
If it was ok that it was the same size as the turbo outlet pipe then the stock licp, ic inlet, ic outlet & uicp would all be less than 1.5" in diameter. Why not throw the throttle body in there as well because it wouldn't be a restriction because the size of the turbo outlet pipe is only 1.5".
Seriously its like comparing a big McDonalds straw to a crazy straw. What is going to allow you to work the milkshake quicker?
The real question is... how can you claim that it is not a restriction?
Nobody claimed that it was a brick wall type restriction... but it is a restriction. Nobody claimed that it is a miracle mod... it is a very minor mod that might only provide very minor increase at all. It definitely makes the turbo spool quicker & I would imagine that there is some power gain. Isn't that enough?
Well this isn't my thread so I'm gonna step out. I'll go along with it being 1.5" longer and maybe has more bends.
Personally I think its worth keeping the stock one and I'll believe that until I see a dyno that can actually show gains. A dyno from other than some flipping vendor that s trying to sell me a $200 "U" shaped pipe and claim the cost is justified because of R&D. The LICP design hasn't changed much since the DSM.
I have recently installed AMS LICP and Greddy Upper Pipe and right after the installation I felt quicker (250-300 rpm) spool-up of the turbo and more direct feel of throttle response. I have no proof of it on the dyno but on the but-dyno there is definitely a difference without any ECU tuning. The boost levels are as before: 1,45 bars top and goes back to 1,2 bars. The only negative thing about it would be that the kicking in and out of turbo is felt more in city traffic where you go constantly between 2000rpm and 3500 rpm. At the end of the day I am very happy with this mod. (Pics of only Greddy UICP)
I too, would like to see a Dyno of the stock LICP vs. an after market LICP on a stock 16G turbo at 20 to 23 lbs of boost. "As proof of the gains"
I was always under the impression that the narrowing of the Stock LICP was designed to increase air speed before entering the FMIC.
Think of it like blowing threw a regular drinking straw vs. a bigger fast food drinking straw. Yes, the bigger drinking straw flows air easier but, the regular drinking straw helps build more speed and pressure from the same amount of breath do to its smaller diameter.
Look at the placement,
Stock Evo IX Lower IC Pipe...
http://rides.webshots.com/photo/2847...29046835QndKEx
