I got a Huge Problem
Old Apr 12, 2007 | 05:09 PM
Ohitsmark's Avatar
I have a stock evo that had a problem that start off with only boosting problems not since ive changed acouple of parts such as AMS 3' TBE // now the problem is that i installed a INJEN upper and lower I/C piping with short ram intake and when i took it around the block it was hitting 30psi "WTF" what happen'd
Old Apr 12, 2007 | 05:11 PM
idriveanevo's Avatar
check your boost solenoid connections
Old Apr 12, 2007 | 05:12 PM
Ohitsmark's Avatar
my boost solenoid in shot... it doesnt work
Old Apr 12, 2007 | 05:13 PM
ok, what do you use to control your boost now?
Old Apr 12, 2007 | 05:17 PM
Ohitsmark's Avatar
right now im using the stock wastegate boost
Old Apr 12, 2007 | 05:19 PM
eve-slow's Avatar
Do you have lines hooked up to your wastegate?
Old Apr 12, 2007 | 05:22 PM
if your only using the pressure from the stock wg it should mybe hit 15 psi if that. do you have it hooked directly to the turbo?
Ohitsmark's Avatar
yup.. factory set up...
Old Apr 12, 2007 | 05:23 PM
zlancer's Avatar
i would stop messin with your car cause it sounds like u have no idea what your doin...take it to a pro.
Old Apr 12, 2007 | 05:25 PM
meaning it still connected to your "shot" solenoid. try getting a short piece of hose and connect directly from your wg to the turbo nipple that was used to go to the solenoid
Old Apr 12, 2007 | 05:55 PM
BBS's Avatar
BBS
longest run-off if I ever saw.
