Rear jack stand points...
Old Apr 14, 2007 | 05:58 PM
amstel78's Avatar
Is it ok to use the "skid" plate area on the rear frame rail for jack stands? To clarify, the rear frame rail has these little metal skid plates bolted on. The metal around that area seems to be overlapped and reinforced. Did a search, and most suggest using the notched side lip for placing stands, but I did not have notched stands (so the metal lip wouldn't crush).
Old Apr 14, 2007 | 06:02 PM
ak47po's Avatar
Old Apr 14, 2007 | 06:05 PM
amstel78's Avatar
Yes, I've seen that and read it. However, my stands are wide and not notched. I could not place them under the pinch seam without crushing it. Instead, I placed the rear stands directly under those little skid plates which are bolted to the rear frame rails. I just wanted to clarify that that area is ok and strong enough to support the vehicle. I had the car up for about 4 hours earlier with the stands there, and didn't notice any crushing of the metal. Just wanted to make sure...
Old Apr 14, 2007 | 08:14 PM
Kerr's Avatar
Fomer Vendor
I use the skid plates for my stands. Hasn't crushed me yet.
Old Apr 14, 2007 | 09:48 PM
BBS's Avatar
BBS
I really wouldn't gamble with my life. Especially if you can get 4 jack stands with the notches for 50 bucks.
Old Apr 15, 2007 | 07:25 PM
amstel78's Avatar
Any other opinions? What are those skid like plates for anyway if they aren't a suitable support surface? The steel frame rail underneath them seem to be reinforced.
Old Apr 15, 2007 | 07:53 PM
YELOEVOVIII's Avatar
i use rubber pads with jack stands on the drip edge and it works great
Old Apr 15, 2007 | 07:56 PM
Tristar's Avatar
Can someone please show me where stands exist that have the notch? Ill buy 4 on the spot. Every one I have seen has notches that are too shallow and would crush the pinch.
Old Apr 15, 2007 | 11:35 PM
ChuckP's Avatar
I always jack the car up on the framerail, and place my jackstands there too. Never had a problem on my G35 coupe or Evo.
Old Apr 15, 2007 | 11:37 PM
EvoRecordSetter's Avatar
we accdidently knocked a hole in the bottom of my friends car when the jack fell off lol
Old Apr 15, 2007 | 11:44 PM
AWDaddict's Avatar
Get a block of wood and cut a gap in the middle.
Old Apr 16, 2007 | 11:36 PM
ChuckP's Avatar
And watch it crack in half...
Use a modified hockey puck if you really need to lift at the pinch weld with a floor jack.
Old Apr 16, 2007 | 11:40 PM
LancerEVA06's Avatar
I use a frame rail... never used the pinch seam... works well, just use a rubber block otherwise you'll put dimples from the jack in the rail.
Old Apr 17, 2007 | 05:13 AM
BlackSport350's Avatar
LOL, you know it! The hockey puck is really good advice and much lower profile then a 2X4.
I have also used 3/4" thick oak with the weld going against the grain but the hockey puck would acheive the same results and be better.
Old Apr 17, 2007 | 08:58 AM
19psi's Avatar
I dont know about some of you..but I wouldn't use a piece of wood.
I was doing this last weekend and the piece of wood cracked while I was under the car.
I almost sh*t my pants...but luckily I had jack stands underneath the car.
Not a very good idea.
junk1337
Evo X How Tos / Installations
60
Jul 22, 2016 03:27 PM
kyoo
Sep 13, 2013 10:03 PM
Flip
Mar 4, 2011 08:01 AM
westmc
Apr 11, 2010 11:16 AM
Poondoggs
May 22, 2009 06:57 PM
