Car won't turn off!
Old Apr 19, 2007 | 07:47 PM
  #46
BBYBruno's Avatar
Originally Posted by gsrboi80
BBY I also had the windshield wiper issue and fixed my self by hard soldering the wires to every connector behind that kick panel.
I also found how the water was getting in and fixed that problem as well. They probably hard soldered the wires to just the one white connector behind there that controls the wipers and lights.
Pull the Schematic on the connector previously mentioned and take the connector apart chances are those pins are corroded as well
For all you guys the water gets in though the gromet located on the drivers side inner fender well then runs down the harrness to the connector and corrodes the pins. This normally attacks the wipers and lights but there are about 6 or 7 connectors behind there
Anyone in the NE I will solder all the wires and fix it up for you cheap. No more water getting in my car and no more wild wipers and lights
Great info. Thanks!
Old Apr 19, 2007 | 07:48 PM
  #47
BBYBruno's Avatar
Originally Posted by Dennis F
Find connector C129, take it apart and look for water intrusion. Looking at the wiring diagrams, that is your most likely spot for a problem. It takes VERY little water to cause weird issues like this. C129 is described as Front wiring harness and instrument panel wiring harness connector. And yeah, the horn signal to the relay runs through that connector also. The connector is located behind the drivers kick panel. Should have 2 rows of wires with 25 wires total.
A local had the same problem.
Great info also. Thanks for helping!
We'll take a look at C129 at the shop tomorrow.
Old Apr 20, 2007 | 04:24 AM
  #48
dadriva's Avatar
I think the problem is that you suck, and therefore your car sucks just as hard as you do.
Old Apr 20, 2007 | 04:44 AM
  #49
XxK1LLAxX's Avatar
this is one of the craziest things i have ever seen....hope you get it fixed bro!
Old Apr 20, 2007 | 07:09 AM
  #50
oldscholevo's Avatar
?? did he **** you off some how ??
Old Apr 20, 2007 | 07:18 AM
  #51
bluebyu36's Avatar
lol
Old Apr 20, 2007 | 07:25 AM
  #52
MisterEVO04's Avatar
Originally Posted by jvlazzar
refer to your local exorcist.
+1
Good luck with, hope its a minor and cheap fix...
Old Apr 20, 2007 | 07:27 AM
  #53
AutobonEvo's Avatar
dude u have a herbie evo ahahah. Thats Fawked.
Old Apr 20, 2007 | 07:32 AM
  #54
bluebyu36's Avatar
a lose wire on the alt. made my car crazy for a couple of weeks........
Old Apr 20, 2007 | 07:38 AM
  #55
Azntoyhere's Avatar
LMAOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOO
Old Apr 20, 2007 | 08:04 AM
  #56
PorkRoll's Avatar
I have the same exact issues, it is becomig a big pain in the a**. every time it rains it starts all over again. Here is a link that shows the harnesses that are getting wet. hope it helps.
https://www.evolutionm.net/forums/sh...d.php?t=252161
Old Apr 20, 2007 | 08:56 AM
  #57
BBYBruno's Avatar
Everyone thanks for the help! I'm taking the car back to the shop on monday with all this new info. I'll update you guys.
Old Apr 20, 2007 | 09:34 AM
  #58
BBYBruno's Avatar
Can you show me where C129 is on the wiring diagram? Thanks.
Old Apr 20, 2007 | 10:30 AM
  #59
BBYBruno's Avatar
Does any one know how to disconnect the immobilizer? If so please pm instructions I am working on the car in my garage and i'm ripping out corroded green wires/connectors. POS 03'!
I'll post pics soon...
Old Apr 20, 2007 | 10:35 AM
  #60
esevo's Avatar
they shouldnt post it lol... or a lot of evos will go missing! PM it...
