Car won't turn off!
Old Apr 20, 2007 | 07:31 PM
  #91
gsrboi80's Avatar
Originally Posted by Dennis F
Like I said earlier on, it is c129 in the driver kick. I have allready gone through the entire car and when I disconnected that plug, the car turned off.
There was nothing I could do to repair it and the whole engine harness had to be replaced.
The immobilizer has nothing to do with this problem and you can not disable it. Your problem is soley in that connector.
I took all of those connectors out of the equation permenently
Garunteed never to happen again
Old Apr 20, 2007 | 10:11 PM
  #92
BBYBruno's Avatar
Ok so are you saying I have to replace my whole engine harness? And where exactly is C129. Can you take a pic and point it out, please. Thanks.
Old Apr 20, 2007 | 10:46 PM
  #93
xanderracing's Avatar
hey, i just read the first page of this... but if your interested, ill trade my 03 lancer for your possesed evo... :\
Well now that i think about it, you could probaly get more by stripping the parts and selling
- poor me...
Old Apr 21, 2007 | 05:44 AM
  #94
Dennis F's Avatar
You are holding it in post #61, 3rd picture down.
*I* did not fix this problem myself, dealer did under warrenty. I just found out that plug was to blame for all of it.
Old Apr 21, 2007 | 07:32 AM
  #95
DanJ's Avatar
It's good to know that there is a somewhat simple solution to these possessed evos. It seems as though a few evos are showing these exact symptoms. So is the water coming in from the grommet by the drivers side kick panel? if so is it because the grommet has been tampered with (ie. boost gauge installs and sub wiring)
Old Apr 21, 2007 | 08:00 AM
  #96
gsrboi80's Avatar
No not previously tampered with. Just a bad factoy seal point. Mitsu runs the Sports meter kit gauges through the passenger side grommet.
This is mainly do to the front winshield drivers side drain gutter drains right on that grommet.
The sunroof drain is in the same spot but does not pour on the grommet.
By repalcing the harrness this will only happen again in the same amount of time if not sooner than it has happened now if you dont seal the water from coming in.
F them pins hard solder the wires together water cant get too it then
Old Apr 21, 2007 | 09:50 AM
  #97
BBYBruno's Avatar
- poor me...
Sorry no deal. It's seems to be an easy fix with everyone's help.
Old Apr 21, 2007 | 09:52 AM
  #98
BBYBruno's Avatar
Ok sounds good i'll tell the shop to hard wire everything in C129 and seal off these water passages. Thanks for the info
Old Apr 21, 2007 | 10:29 AM
  #99
Talon's Avatar
Just trade it in for the Cavi' straight up.
Old Apr 21, 2007 | 12:31 PM
  #100
BBYBruno's Avatar
Well I just went to the car to test out the C129 connector and.........Eureka!! Problem found. When I unplug that connecter and put the key in and turn it to "ON" all the dash lights come on like there supposed to. When I take the key out they turn off like there suppposed to. And when I plug that connector back in without the key in the ignition all dash lights come on.
So like a lot of people advised i'll have all those wires hard wired and water passages sealed.
I want to thank everyone for all the useful info. And if anyone else has problems like this they have good info from this thread to solve there problem.
Old Apr 21, 2007 | 12:55 PM
  #101
Talon's Avatar
You're welcome... glad I could help.
Old Apr 21, 2007 | 12:57 PM
  #102
BBYBruno's Avatar
Shut up
Old Apr 21, 2007 | 01:19 PM
  #103
gsrboi80's Avatar
Your welcome BBY glad I can help
No reason to get rid of your cars guys its an easy fix that is garunteed never to come back
Old Apr 21, 2007 | 08:06 PM
  #104
BBYBruno's Avatar
SUCCESS!!
Took my car to my friend's house tongight (Brian Dragnic) and he hardwired all the wires for me and everything is working fine now. Thanks for the help everyone.
Update: While I was driving home I noticed my headunit has no power. Where is the fuse for the radio located, so I can check it. I don't know what else it could be. All we did was remove connector C129 and hardwire all the wires. We did one wire at a time so we wouldn't mess up. Any help once again would be appreciated. Thanks...
Should I check fuses 20,22,23?
Update: Well went outside to check fuses 20,22,23. First I pulled out 20 (looked good) and put it back in. Then pulled out that yellow plastic casing holding both fuses 22 &23. When I put it back in my lights turned on so I went inside the car put in the key, turned to "ON" and the radio turned on.
So basically EVERYTHING is working now.
JTJB
Lancer Troubleshooting
17
Jul 14, 2025 08:06 AM
Eisen7
Nov 20, 2014 02:44 AM
Mrxgrimreaperx
Jun 28, 2011 06:42 AM
tyneusch
11
Aug 28, 2010 03:24 PM
EVOXTC
23
Apr 10, 2004 12:50 AM
