Aem Ems Shut Off Problems
Old Apr 26, 2007 | 01:18 PM
nubi4life's Avatar
I just recently had my car tuned by turbo trix racing in edison newjersey. i have to keep cranking my car just to start it. i have an aem ems installed. if i dont start it in a couple of days. it wont start at all. please help.....thanx
Old Apr 26, 2007 | 02:01 PM
Kevin Knight's Avatar
? have no idea sounds odd ? should of got AMS to tune it lol
Old Apr 26, 2007 | 03:00 PM
cssaddictm4's Avatar
How many cranks to start it? What temperature is it when it takes awhile to crank?
I have the AEM on my IX and it takes usually 3-6cranks to get going with temps around 40-60*F. Near freezing takes a few tries (12-16cranks). When you try to restart it after a few days is it because your battery is drained? I read that the AEM EMS would not shut off on a few cars and drained the battery.
Just so you know I wouldn't crank more than 10sec at a time so you don't damage the starter. Sounds like a possible tweak in your coolant temp start parameters. Give the tuner a call, if you have a laptop you can log it and they usually wouldn't mind sending a revised *cal file.
Old Apr 26, 2007 | 03:54 PM
o6RSEvo's Avatar
i have the same problem
Old Apr 27, 2007 | 05:56 AM
milo's Avatar
Sounds like AEM has driveability issues
Old Apr 27, 2007 | 05:59 AM
dadriva's Avatar
Not true at all. You just have to make sure you have someone that knows the AEM EMS inside and out set it up for you.
I had David Buschur set mine up and it is flawless. I can't speak for other shops but I have zero issues even when we have crazy temperature swings here in Ohio.
Old Apr 27, 2007 | 06:17 AM
milo's Avatar
Thats good to know........considering I purchase for my Evo 9
I should have it installed by next week.
Old Apr 27, 2007 | 06:57 AM
oldscholevo's Avatar
battery drain?
Old Apr 27, 2007 | 11:02 AM
nubi4life's Avatar
well, when i got it out the shop from the beginning it took like 5 cranks to start it. but turbotrix said its normal and the aem takes time to adjust and then it will stop. now, my car wont start at all. i even tried to jump it and fail for the fuel pump to cut off. its kind of odd that i try to call turbo trix about my problem and they dont even answer my call. they stopped when i paid them.
Old Apr 27, 2007 | 11:28 AM
binh's Avatar
some of your parameters in the engine start menu are off. I can send you my map so you can compare them.
Mine starts up fine in just about every weather condition.
Old Apr 28, 2007 | 09:29 AM
nubi4life's Avatar
thanx
if you could i would greatly apprecitate it. thanx
Old Apr 28, 2007 | 10:25 AM
binh's Avatar
PM me your email...
atcmac3
AEM EMS
Mar 17, 2011 07:07 PM
Nismo2evoawd
AEM EMS
10
Jan 20, 2011 08:08 AM
Ekoy
AEM EMS
Apr 21, 2009 07:17 PM
apevo8
AEM EMS
Dec 27, 2006 05:12 AM
evo12345
AEM EMS
Sep 27, 2006 03:34 PM
