Methods of Reducing Rotating Mass Weight
Old Apr 29, 2007 | 03:57 PM
  #31
matyb's Avatar
alittle off topic but the same genre....
since we all primarily measure whp, i would love to see the gain if any of a wheel and tire swap. im sure there would be gains but what they would be would be very interesting.
Old Apr 29, 2007 | 04:03 PM
  #32
_EVOlved_'s Avatar
It would be. I still want to know my correction factor
Old Apr 29, 2007 | 05:45 PM
  #33
Vigo's Avatar
I'm guessing that the Torqline CTG carbon fiber driveshaft sold by AMS will give you about 32whp. It's 40 pounds lighter than stock.
Old Apr 29, 2007 | 06:20 PM
  #34
_EVOlved_'s Avatar
Its a ton of money!
Old Apr 29, 2007 | 08:31 PM
  #35
Vigo's Avatar
Yeah, it sure is.
Old Apr 29, 2007 | 08:34 PM
  #36
91TB78's Avatar
Contact ACPT...they make awesome carbon fiber driveshafts.
Old Apr 29, 2007 | 09:01 PM
  #37
_EVOlved_'s Avatar
Kk
Old Apr 29, 2007 | 09:33 PM
  #38
Agent-Smith's Avatar
Originally Posted by Kryptonite
We did this to our ring gear recently to lessen rotating mass (note: this ring gear is NOT in the Evo, but you get the idea)
Started as 12 lb, machined 4.5 lbs off of it.....quite a common practice for 9" ford rear ends
Yeah I would not recommend this to anyone. With ring & pinion gears are already a weak point in the evo driveline. (transfercase anyone?)
Old Apr 29, 2007 | 10:00 PM
  #39
_EVOlved_'s Avatar
I wouldnt
Old Apr 30, 2007 | 06:14 AM
  #40
mot's Avatar
mot
we have pretty much got everything you can do
work your way in from the outside starting with tire
rim
rotor MAYBE caliper not sure if aftermarket kits are lighter but i doubt it
then suspension
i know my jics were way lighter then the stock set up
and my ohlins are now even lighter than my jics
i also got a hollow hotchkiss sway bar and power agency lower control arms which are 1lb savings
not sure if things like that are unsprung weight but im sure theyll help
Old Apr 30, 2007 | 07:26 AM
  #41
Kryptonite's Avatar
The ring gear was just an example of what you could potentially do in some form of elimination of rotating mass....I wasn't suggesting to do it to the Evo, but there may be other items to consider. Just throwing out an idea used in alot of racing applications. That set up works wonders for us
Carbon Fiber Rotors....
Old Apr 30, 2007 | 07:36 AM
  #42
vigilante's Avatar
Eliminate balancer shafts
Old Apr 30, 2007 | 08:26 AM
  #43
_EVOlved_'s Avatar
Who makes real light tires?
Old Apr 30, 2007 | 01:08 PM
  #44
91TB78's Avatar
check out www.edgeracing.com. They have a lot of weights on their site of specific sizes, models, and brands. There is a trade-off with rigidity, but depends on what you're looking for.
Old Apr 30, 2007 | 01:23 PM
  #45
Kevin Knight's Avatar
why do u care about the weight again, just make the B!tch faster and dont worry about the weight.
