Name That Decel Noise! (PLEASE)
Old May 3, 2007 | 08:59 AM
Rez90's Avatar
that clutch with the evo tranny makes quite a bit of noise on decel. i woudln't worry about it..........
Old May 3, 2007 | 10:58 AM
monies41's Avatar
Originally Posted by mad_VIII
Sounds like the TC, like the beginings of the death whine. Twins normally make more of a rattling than a whining. If the whining gets to the point that it is loud then you need to call shep and get a new tc.
My twin disk makes a nice rattle, on top of that I have the old decel noise. I Installed the twindisk at the same time I replaced my Tc. All three are distinct noises.
Decel noise is a tough to describe rattle, Twin disk is a more obvious rattle. TC on it's way out is a siren like whine or howel when on light to no throttle.
Drain your tc and look for shavings.
I am really starting to believe that it may not be the transfer case. I think it may be a issue with the clutch+6 sp. Cany anyone else verify that their 6 speed does this with this clutch. I do have a slight whine in 6th and sometimes 5th. I guess only time will tell.
My car has also never been launched, ever!
Old May 3, 2007 | 02:54 PM
Danny23's Avatar
The decel noise is normal for a twin. I had the exedy twin in my 03 8 and had the same decel noise. I have an ACT MB7 HDSS w/ prolight flywheel and it makes absolutly no noise at all.
Old May 3, 2007 | 06:50 PM
monies41's Avatar
i hope it isnt the t case
Old May 3, 2007 | 07:49 PM
Nvr2old32's Avatar
It's not the T-Case. It's the damn clutch. I've had that noise ever since I had my Exedy Twin disk installed.
Noise from a T-Case going bad is much more obvious (In most cases)
Old May 6, 2007 | 07:08 AM
DeiPro's Avatar
Originally Posted by monies41
so you think it could just be the clutch? Did he have a 6 sp or 5
Yes, I think it is the clutch. The customer of mine had a 5spd. I have heard those exedys make noise on both 5 and 6spd cars, its not a function of number of gears.
If you are going to spend the money, I would suggest doing it on a Tilton Twin ceramatallic.
Old May 6, 2007 | 07:19 AM
Lancematic's Avatar
My exedy HD td does the same thing
Old May 6, 2007 | 08:21 AM
yikez's Avatar
does not sound a t-case .. if it was the t-case you would have it when slowing down at neutral as well
Old May 6, 2007 | 11:09 AM
EvO6-RS2's Avatar
It's the clutch!!
I know from personal experience that both Exedy & Tilton twin disc clutch kits make noise on decel.
Nothing you can do about it, but jus live with it or change the clutch.
Old May 6, 2007 | 11:23 AM
lilnaz's Avatar
Twin exedy hd on 6-spd, No decel sounds like you are explaining. Only sounds are a weird loud chewbacca sound when engaging clutch.
Dross99_si
13
Sep 16, 2016 10:57 PM
PATRICK B.
Jun 6, 2008 09:57 AM
MyEvoRocksUrv8
10
Feb 22, 2007 10:28 PM
Vapor
10
Feb 19, 2007 11:08 AM
Satori
Jul 28, 2006 04:53 PM
