windshield wiper fluid
Old May 3, 2007 | 11:17 AM
gixxerman11's Avatar
do any of yall do this
reroute your fluid hoses to your IC and spary water with that kinda like a IC spary bar
Old May 3, 2007 | 12:35 PM
sonicnofadz's Avatar
My 03 came with an intercooler sprayer from the factory. I removed it, and threw it in the trash.
Old May 3, 2007 | 12:37 PM
SteelEvo's Avatar
why?
Old May 3, 2007 | 12:45 PM
Smike's Avatar
Intesting and no. Now how do you clean your windshield if those are for the IC?
Old May 3, 2007 | 12:46 PM
Spraying liquid onto the intercooler doesn't achieve anything, except maybe it corrodes the aluminum a little bit.
Old May 3, 2007 | 01:22 PM
R33E8's Avatar
I guess you never learned that water dissipates heat much faster than air??? Which is why air-water intercoolers are better for drag racing and other short stuff like that..
Old May 3, 2007 | 01:31 PM
BBS's Avatar
BBS
Oh man. Shoulda thought this one through before you replied. An IC sprayer to resolve some heatsoak issues is one of the quickest and most effecient ways lower your IC temps.
Old May 3, 2007 | 01:59 PM
Go to http://www.dsmtuners.com
Water on the intercooler doesn't do jack ****. I've personally done testing with intercooler sprayers, they don't add any power, and they don't get rid of heat soak. They are worthless, and thats why starting in 05 they are no longer included with the Evo. If you actually believe that spraying water or alky on the intercooler does anything you are kidding yourself.
Old May 3, 2007 | 03:38 PM
keyboard
well what if i sparyed key board cleaner in there that will work
Old May 3, 2007 | 11:04 PM
binarysleep's Avatar
The intercooler spray was omitted in '05 to allow room for components of the ACD.
Spraying your intercooler does "work," but will depend on what you spray (as well as what you define as "work"). Spraying water is least effective as it relies on the dew point, temperature, and more movement of air over the fins. Spraying a compressed gas such as nitrous oxide or carbon dioxide will have greater, but short lived effects.
It's basic physics. Intercoolers use air passing over fins to cool the intake air. Evaporation of water on an object creates lower temperatures of said object. In your case, the difference in temperature might have been negligible, but the laws of physics still apply.
Old May 3, 2007 | 11:09 PM
staatz's Avatar
No, but we took the re-routed it to the back of my friends VW emblem and threw a nozzle. Now it shoots out 20ft behind him depending on how its angled...hahah
Old May 3, 2007 | 11:29 PM
SOEuro's Avatar
i drive an 03 and ive put Alky into the i/c spray and felt no gains,but why would mitsu put it on the evo if it had no effect????im sure they did it for a reason,ur not gonna feel an instant boost like a push from a NAWS button on the steering wheel,put the intake temps will lower
Old May 4, 2007 | 02:08 AM
riceball777's Avatar
does it help of course it does. but it probably wont help enough for you to notice anything. the cooler the intake temps the more power you will make. its like you car will make more power when its 50 degrees compared to 100 degrees.
evole97
11
Aug 28, 2014 09:53 PM
still*boostn
Sep 25, 2010 04:58 PM
OhsixIXBish
Jul 16, 2008 01:01 PM
TurboTimah
32
Jun 26, 2008 01:40 PM
stonerguy169
Jan 28, 2008 07:20 PM
