vortec genrator flew off
Old Jun 2, 2007 | 03:19 PM
NoTec's Avatar
I went factory and never had issues. they even supply you with instructions. Use ipa or some other type of wax degreaser prior to install and it will never fly off.
DRFTKNGG's Avatar
I bought Genuine OEM mitsubishi and it came with the 3M installed already. Been on now for over a year.
Old Jun 2, 2007 | 03:22 PM
DSMEVOLUTION's Avatar
My rexspeed never had a problem. I betyou mounted the tap wrong. I mounted the tap almost to the very edges of the VG and I also put vertical strips on the outer edges and inner right by the antenna. Mine is secure, very secure.
Joshs EVO's Avatar
I had my wind splitter get ripped off. So i feel your pain
Old Jun 2, 2007 | 03:26 PM
evolved83's Avatar
this isnt good to hear because i am about to put mine on!
Old Jun 2, 2007 | 03:30 PM
Czubaka's Avatar
I picked mine up after it flew off. No adhesion left on the tape. Also, I have an MR, so it was a factory install.
Old Jun 2, 2007 | 03:31 PM
homiusang's Avatar
Well, just need to be sure the surface is thoroughly clean with alcohol and buy extra 3m tapes for a more secure installation.
Old Jun 2, 2007 | 05:08 PM
riceball777's Avatar
i used the 3m tape that rex speed provided and taped everywhere like this
i also cleaned the surface of thr roof really well. it so easy to install theres no real way anyone can install it wrong.
i put the vortex generator on at night went to work on the freeway in the moring and at 80mph it flew off. i never got a chance to enjoy it. i had to pad $69 shiped for a plan black one and another $80 to paint it cuz rex speed does not sell blue by you color ones.
so i really want to buy another one i'm just scard the same thing will happen.
Old Jun 2, 2007 | 05:18 PM
IXmr321's Avatar
when i had my mr the vortex generator was sorta loose, but it never flew off lol
Old Jun 2, 2007 | 05:26 PM
chrismnj's Avatar
i did use more tape then that
Old Jun 2, 2007 | 05:42 PM
BBS's Avatar
BBS
By lord please do NOT wax prior to adhering any tape onto the surface. It is not goign to help in the slightest. What you can do it clay the section, wipe it down with some water/alcohol solution.
Did you hop on the freeway right after you installed it? I would've made sure to give it some time to adhere.
Old Jun 2, 2007 | 05:45 PM
yellowbirds58's Avatar
ah crap!
i just put mine on with that much tape.....i hope it doesnt fly off
Old Jun 2, 2007 | 05:48 PM
chrismnj's Avatar
Originally Posted by xxx4reggie
ah crap!
u should be all right i know that i over killed my just make sure u live the car in sunny spot
Old Jun 2, 2007 | 05:58 PM
yup, after i put mine on, i left the car in a sunny spot for an hour, put some weight on it too to kinda make sure it stays, then parked it in the garage. so far 6 hours have gone by and havent driven it, i'll drive it at night and see if it helps.
but this is how i did mine too
Old Jun 2, 2007 | 06:05 PM
TeKiZeRo's Avatar
Do not wax your car before you put that on since the tape will not stick any better because of it. Just clean the surface with alcohol so it removes the wax currently there and any small stuck debris. Then apply the VG after. I've done this to anything I've used 3M on and it sticks like the mother f*cker.
