vortec genrator flew off
Old Jun 2, 2007 | 06:05 PM
  #31
Positron's Avatar
Originally Posted by riceball777
i used the 3m tape that rex speed provided and taped everywhere like this
Thats HELLA tape. I bought a used OEM Mitsu grey VG. It barely had tape on it left and it was used tape too! Slapped it on almost a year ago and nothing has happened ever since .
Riceball, did u install it under the weather channels properly?
Old Jun 2, 2007 | 06:33 PM
  #32
Evolving03's Avatar
Originally Posted by MyEvoDream
Like they say, the VG helps downforce over 100 MPH. I guess in this case it helped by...reducing the weight of the car!
Old Jun 2, 2007 | 08:57 PM
  #33
riceball777's Avatar
yes i installed it under the weather channels
i installed it at night and as soon as i went on the freeway in the morning it flew off after like 5 mins
Old Jun 2, 2007 | 09:09 PM
  #34
LoCo4's Avatar
First off you should have let it set for at least 24 hours before driving. Second, when you thought the surface was clean, clean it again.
Chalk that VG up to an expensive lesson learned.
Old Jun 2, 2007 | 09:12 PM
  #35
4cefed's Avatar
well i got a factory one with less tape than that and i took it past 170, bouncing of the rev limiter in fifth yeaaah!!!!
Old Jun 2, 2007 | 10:55 PM
  #36
yellowbirds58's Avatar
WTF?!!! 170? I get worried when I'm doing 140 and the rpm gets to the red. I bow to you!
so I just came back from a test drive with the VG, took it to 120 a few times, pulled over and checked, so far so good. It's stuck in there good
Old Jun 2, 2007 | 11:05 PM
  #37
kduncan01's Avatar
I know this may seem really basic to you guy but I have my VG to install, how do you remove the weather channels so the clips dont break? Do you remove the weather channels from the back of the car coming forward?
Thanks
Old Jun 2, 2007 | 11:16 PM
  #38
Thanks
open the trunk, then pull the weather channel slowly, very slowly. there are two clips, one is white and the the other is grey. pulling the white loosens the channels and the ghey one gets you to actually pull the channel out.
make sure your gentel with them cuz they will break, what i did was use a flathead wrapped in a towel to leaver the channel and get the grey clips off.
putting it back is the same way, dont rush it! the white clips will move so check on those when you start putting it back together.
its easy but take your time, took me about 30 mins
Old Jun 2, 2007 | 11:27 PM
  #39
kduncan01's Avatar
thanks xxx4reggie!!
Old Jun 2, 2007 | 11:40 PM
  #40
RED DEMON's Avatar
i put mine on over 2 years ago, hasnt come off a single time!
Not to mention its aftermarket, and stuck under the weather stripping on the roof
I am surprised some of them are flying off, i dont even get it vibrating or feel air getting under it
Old Jun 3, 2007 | 07:57 AM
  #41
EvoJarHed's Avatar
looks like a job for elmers glue
Old Jun 3, 2007 | 08:26 AM
  #42
Forrest Gump 9's Avatar
I have an aftermarket unit on my car and it's been solid so far. I guess it's all in the taping. I'll definitely have to keep my eyes on it now.
Old Jun 3, 2007 | 11:04 AM
  #43
Daniel_4g63's Avatar
That sucks! more tape next time
Old Jun 3, 2007 | 11:21 AM
  #44
red evo8's Avatar
i have a rexspeed vg mine stays on up to 162
Old Jun 3, 2007 | 03:06 PM
  #45
RED DEMON's Avatar
so you have the rev limiter taken off or your car retuned?
bcuz im pretty sure the evo stock ECU has a govenor/rev limiter at 158 in 5th
