Broken bolt on hotside
Old Jun 11, 2007 | 05:31 AM
subrwho's Avatar
Arrow Broken bolt on hotside
While taking some things off, one of the bolts that connects the hotside to the turbo manifold snapped in half. Any ideas on how to get the broken part out of the hotside? I tried drilling it out, but had no luck.
Old Jun 11, 2007 | 05:59 AM
pulley1fan's Avatar
Man... I know what I would do... and thats cry.
Old Jun 11, 2007 | 06:37 AM
belizelittle39439's Avatar
Wow...you do run into a lot of problems with your car. You're going to have to drill into it with a specialized bit that when turned in the counterclockwise direction will remove what is now a threaded stud.
Go to Sears, they should have what you need there.
Old Jun 11, 2007 | 06:42 AM
Speed Corps's Avatar
Former Vendor
It's a bolt extractor. On these bolts it's a real pain because they are hardened, so drilling will be a *****. You have to get the good drill bits, the cheap ones will dull quickly. If that don't work, drill it all out and get a heli-coil. It's a spring like piece that you put in the hole and the bolt threads into it. Any car parts store will have these. good luck.
Old Jun 11, 2007 | 06:44 AM
schred86's Avatar
can u at least thread a nut on it?
Old Jun 11, 2007 | 07:02 AM
Lazeum's Avatar
One of my friend tried to weld a nut on the top of the bolt. Out of 3 bolts he was able to remove one. maybe you can give a try...
Otherwise, the bolt extractor might be your best friend.
Old Jun 11, 2007 | 11:03 AM
JakeTheVIII's Avatar
Same thing happened to me a while back. I drilled for days and eventually had to take the turbo off and use an angle grinder to make a small slice into the side of the hole, and cut the bolt out. Leaves a small gap in the bolt hole, but works perfect still....going on 6 months like that with stock hotside/turbo and no leaks.
Old Jun 11, 2007 | 11:22 AM
I'm having a hard time visualizing what you're talking about....you did what now?
Old Jun 11, 2007 | 11:24 AM
Clutchdc5's Avatar
haha
Old Jun 11, 2007 | 01:44 PM
heavens turbo's Avatar
take the thing to a machine shop. $50 bucks and they'll get it out. how's the search for the sti?
Old Jun 11, 2007 | 02:07 PM
DanJ's Avatar
I would invest in a bolt extractor kit from sears. It costs around $30 but it will save your *** a few times. I've already used my bolt extractor kit several times.
Old Jun 11, 2007 | 02:13 PM
subrwho's Avatar
will the bolt extractor get it out? `And nope I can't get a nut on it
Old Jun 11, 2007 | 02:37 PM
DanJ's Avatar
It should. All you do is drill a hole about .5cm and then put on the bolt extractor. Basically it drills into the bolt while extracting it. If that doesn't work your just gonna have to drill it out completely.
Old Jun 11, 2007 | 02:38 PM
subrwho's Avatar
ok i'll try that. Thanks for your help!
Old Aug 26, 2007 | 01:03 AM
mvm42699's Avatar
From: 85296, 99519, 96817,98310,07306,10461(HomeSweetHome), & 00739
This **** just happen to me today. The bolt just snap in half while trying to unscrew it. What a nightmare! I hope I'm able to get it out because it's on the hotside.
BTW. Anyone know an ARP brand replacement? The 2 stock bolts that connects the Exhaust manifold to the hotside tends to weaken overtime.
