low beam adjustment
Old Jun 28, 2003 | 12:26 PM
350ZTracktoEvo8's Avatar
low beam adjustment
the low beam shines a bit lower than the right, is there an adjustment to bring it up a bit?
Old Jun 28, 2003 | 12:35 PM
KINGEVO7's Avatar
i dont have evo yet but as with all cars there should be an independent bulb angle adjustment on the back of the head lamp assembly i guess u can level them with each other and then only use the incar adjustment nob.
Old Jun 28, 2003 | 12:57 PM
2Cool's Avatar
Search for headlight adjustment, there were pics showing the gear/10mm bolt head on the reverse of the light assembly that controls the HID angle. I have mine dialed up so the the middle setting of the in-car dial is right for driving, so I can dial them up or down from that point.
Old Jun 28, 2003 | 01:12 PM
Hedonic Tread's Avatar
Re: low beam adjustment
Sounds like a perfect opportunity to take advantage of that warantee! Why mess with manual adjustments when the dealer will do if for you?
Old Jun 28, 2003 | 01:30 PM
Hi guys, this 10mm bolt, is it capped over by a translucent plastic cap with 4 slots?
Old Jun 28, 2003 | 01:31 PM
oops, 3 slots. Hard to see in the midday sun!
Old Jun 28, 2003 | 02:15 PM
Lightsped's Avatar
On a related note:
What exactly is the reason one would want to adjust your headlights? I mean, if you need more light use the highbeams or fogs. I don't understand the real logic behind a headlight adjustment switch?
I keep my lowbeam lights as high as they go which seems about normal compared to other cars. No one has flashed me or told me they were too bright.
Old Jun 28, 2003 | 05:13 PM
2Cool's Avatar
No cap on the adjustment screw, look lower down, in the middle of the light assembly.
And the stock setting is way low, with lowbeams on at interstate speeds you overdrive them. After swerving around a chunk of semi truck tire that just "appeared" in my lights, I wanted them up higher. Its easy to do, makes driving at night less stressful, and why the heck not do such a simple adjustment on your own?
john blaze
Jul 31, 2016 06:56 AM
tiesto14
14
May 19, 2016 08:52 PM
Tommyy
12
Nov 3, 2015 05:52 AM
trev0006
Sep 28, 2003 10:38 AM
novabluebyyou
16
Jul 25, 2003 04:13 AM
