Alarm / Security System Help
Old Jul 24, 2007 | 04:36 AM
SuperStreet2K6's Avatar
I bought a car that had a ghetto rigged security system on it and I am trying to remove it and return it to stock. Does anyone have a wiring diagram or a how to for wiring up the stock system? I just want the locks working again with the key fob. If no one even has these things, could you get me started in the right direction by telling me where the stock alarm system is located in the car? I have the dash out right now so it would be easy access if it is there. Thanks in advance!
Scott
Old Jul 24, 2007 | 09:48 PM
mrfred's Avatar
The factory service manual should have the wiring diagram.
Old Jul 25, 2007 | 04:08 AM
Unfortunately, the service manual was not in the car when I bought it. Any idea where the keyless entry module is located?
Old Jul 25, 2007 | 06:05 AM
mrfred's Avatar
Have you tried looking on BT for an FSM? I think if you search on EVO9US_FSM at mininova.org, you'll find one.
Old Jul 25, 2007 | 06:41 AM
rice_rocket88's Avatar
Just reprogram the Key FOB.. it should work unless they completely hacked the box up! An aftermarket alarm has a factory disarm pulse to a wire, bit it should not disable the factory key FOB.
Are you sure the factory key fob didn't just run out of batteries?
Old Jul 25, 2007 | 06:57 AM
sblvro's Avatar
I'm surprised that an 06 should have a ghetto security system. If you bought it used and you don't have the complete set of keys=2 keys, just go to the dealer so they can reprogram your ECU. Make sure you bring your registration to confirm that you are the rightful owner! can you show pics of your "new" evo?
Old Jul 31, 2007 | 09:46 AM
This is actually on an 03 that I just bought.
Can you quickly describe how to reprogram the stock key fob?
Old Jul 31, 2007 | 10:02 AM
Emm do a quick search on it, and you'll find it.
As far as I can remember you short 2 pins... or if you have ANY OBDII plug just plug it in. Then turn your key to the "on" but not start position (ie to turn on the radio) and then hit the hazard button 5 times, then you click the lock/unlock button once on each key FOB.
Old Aug 1, 2007 | 04:16 AM
Thanks! I will give that a shot!
Old Aug 9, 2007 | 09:42 AM
phenaly's Avatar
2006 IX MR
EDIT: Noticed you said 2003...heres the wiring.
Evoguy!123
Dec 5, 2016 09:12 PM
bee-raddd
Nov 11, 2015 05:57 PM
evoniners
11
Oct 11, 2015 10:51 AM
jnick
16
Jun 30, 2015 03:35 PM
Deca Auto
West Region
13
Jun 22, 2004 07:37 PM
