emissions
Old Aug 18, 2007 | 08:31 AM
amscrazy's Avatar
emissions
so i was wondering...i have a 05 evo 8 and i have a ams gt30r turbo kit a 3in turboback with test pipe and a new fuel system and an aem ems...i was wondering how i would ever be able to pass emissions
What do you guys think
Old Aug 18, 2007 | 08:33 AM
jamerin's Avatar
With the test pipe on, i'm sure it won't pass....
Old Aug 18, 2007 | 08:34 AM
Psquared's Avatar
You may pass if you put the stock cat. converter back on....
moreryce's Avatar
you'll just have to return things to stock if you want to pass emissions
Old Aug 18, 2007 | 08:38 AM
Roldy's Avatar
Probably have to swap out the test pipe if they do the sniff test and most likely have to swap out your EMS back to your stock ecu because they have to plug a computer in to your OBDII.
Carbonics's Avatar
you would be fine aslong as you dont have a check engine light 96 and newer is all obd
Old Aug 18, 2007 | 08:46 AM
amscrazy's Avatar
well electronicaly i think i would be fine because of the ems but if they decide to look uder the car..the only problem is that the ams down pipe doesnt fit wit the stock cat
Old Aug 18, 2007 | 08:49 AM
alevo8's Avatar
Good luck with that
I know in NYC its not a problem to get a pass
Old Aug 18, 2007 | 08:50 AM
zbomb's Avatar
Dos Illinois require an obd check as part of it's emissions testing. AEM sandalone will not pass obd.
Old Aug 18, 2007 | 09:06 AM
amscrazy's Avatar
i dont even know what an obd is
Old Aug 18, 2007 | 09:27 AM
W_evo8's Avatar
Bribe the tester to get you a sticker or become friends with an emission tester.
Old Aug 18, 2007 | 10:33 AM
06RS's Avatar
Get a Spark plug Non-Fouler. It's a $5 fix that tricks your second O2 Sensor into thinking that your Catalytic Converter is working properly.
https://www.evolutionm.net/forums/sh...rk+plug+fouler
Your car will pass the emmisions test as long as your Check Engine light is not on. The only problem that you could face; is if the shop performs a visual inspection. If your concerned about that, you can weld the stock Catalytic Converters shell on top of your test pipe.
Old Aug 18, 2007 | 12:18 PM
amscrazy's Avatar
thanks for the info man that helps alot
Old Aug 19, 2007 | 12:39 PM
hytek369's Avatar
onboard diagnostics
Old Aug 19, 2007 | 12:44 PM
wizzo 8's Avatar
In Illinois cars 96 and newer dont get sniff tested. All they do is plug into the obd connector and read out fault codes. If no codes stored you pass. They dont even check for a catalitic converter. I would put one on just in case they do check but thats up to you.
