Car acting weird....First signs of Clutch???
Old Aug 19, 2007 | 06:47 AM
AUSS1E's Avatar
I just did the ETS FMIC and upper and lower pipes. Shortly after I have noticed that if I am cruising along in any gear and then stomp on it, the boost builds and the car accelerates until it hits about 10psi and then it feels like the clutch slips and then grabs again once it hits 21psi.
Although when I did a launch to see how bad it was slipping it seemed as if it didnt slip at all, all the way thru the gears to 100. I also tried to start in 5th and the car just died. So it is baffling me as to whether this is the clutch or not.
I didnt get a reflash after the IC install, But I wouldnt think that to be the issue the way it is behaving.
I just wanted to get some opinions before I started on the clutch.
Thanks in adv.
BTW. Clutch is stock with about 30000miles on it.
Old Aug 19, 2007 | 09:10 PM
SpeedJunkyz's Avatar
def sounds like the clutch,
Mine did the same around 21,000 miles then didnt do it again until about 23,000, finally blowing out around 25,000.
My discription was, around 3k rpm it would slip until 5k rpm then grab again.
Old Aug 19, 2007 | 10:59 PM
eponti's Avatar
can you smell the clutch burning?
Old Aug 19, 2007 | 11:19 PM
badhabit90's Avatar
sounds like an intercooler pipe not on all the way. check connections, you may have a boost leaks causing the MAF to read high knock count and then give the timing back-10psi then back to 21psi.....
Old Aug 20, 2007 | 01:03 AM
Wishin4boost's Avatar
Check your IP ...because this happen on my GSX.... Im almost sure thats what it is
Old Aug 20, 2007 | 01:56 AM
SOEuro's Avatar
boost leak test it
Old Aug 20, 2007 | 04:32 AM
tonyevo123's Avatar
Same Thing Happen To Me And It Was Def Clucth
Old Aug 20, 2007 | 11:39 AM
AUSS1E's Avatar
No clutch smell...that is real noticeable. Although slightly when I am stopped.
Old Aug 20, 2007 | 11:42 AM
AUSS1E's Avatar
I will check em. But it boosts solid and steady all the way up to 22psi (Gotta turn that down). The engine seems like it is still pulling hard.
But if it is the clutch just strange that it grabs at full boost rather than slip until you get out of the gas.
And now it is tending to do it a little earlier, around 5psi
MitsuJDM
19
Nov 9, 2016 03:47 PM
Evo10HKS
Aug 10, 2016 06:14 AM
evo robert
Sep 2, 2015 09:29 AM
bboypuertoroc
16
Mar 22, 2011 11:22 PM
str8kor
Oct 30, 2009 07:52 AM
