So I overreved..what did I break?
Old Aug 29, 2007 | 04:16 PM
badstainless's Avatar
Originally Posted by 4 Wheel Slide
update?
+1
Old Aug 29, 2007 | 04:18 PM
bluebyu36's Avatar
i would defnitly do a compression test ....
Old Aug 29, 2007 | 04:30 PM
TurboIX's Avatar
Fluid on the TC case came out fine same with tranny fuid....As of now We're going to take the tranny apart and go from there. I asked Shep if He's seen a tranny whine before and He said " not normally". So pretty much He hasnt seen a tranny make this kind of Whine. He told me TC is usually what makes a whine.
Old Aug 29, 2007 | 04:33 PM
TurboIX's Avatar
But again why would the TC be messed up from a Overrev?..
Old Aug 29, 2007 | 04:38 PM
4WS Tuning's Avatar
the TC could have been shocked from the rpm flying up cause im sure the car shot forward pretty hard....
kinda like a rolling launch...
Cheers!
Old Aug 30, 2007 | 01:52 AM
EvoInvidia's Avatar
He wont be able to check his OBDII. Unless his CEL is on. Even if it were on, it wouldnt say anything about the tcase or clutch parts.
Old Aug 30, 2007 | 06:38 AM
GotBoOst05's Avatar
take it to the dealer
Old Aug 30, 2007 | 07:02 AM
rcheung's Avatar
That would not be the best idea. Not only will they possibly not warranty the repair for abuse but they will charge you an arm and a leg for stock parts when Shep can rebuild it much stronger than it ever was for less money.
Old Aug 31, 2007 | 09:22 PM
$ilverEvo's Avatar
did the same thing but had a Acura RSX ivtech. Was redlined at 8500 in 3rd gear and shifted as fast as i could into 2nd gear by accident. My cylinder exploded in my engine. The service tech told there was metal shaving in my engine oil. The regional rep for acura came down and gave me a long explanation of what happened. But he was cool and replaced everything, the whole engine. I would check your oil first or timing belt
Old Aug 31, 2007 | 09:32 PM
evoracingstar's Avatar
So I was at the track and I miss-shift from 2nd to 1st. I was trying to put it in 3rd but it got stuck and it some how poped into 1st. I quickly put the clutch in and put in neutral.
After it happened I couldnt put it into gear. But after a little while it started going into gear but it wasnt as smooth as before. My problem however is this huge Whine!!. The Whine is louder then my exhaust, like a plane.
I had it checked out and my local shop says it's comming from the tranny...He said he spoted the noise and it wasnt the transfer-case or Engine.
is this normal for a overrev?...I would of thought the engine would go before the tranny...But he said the engine is fine. I should probably do a compression test just in case.
thoughts on this?
humm.. a whinee haa?? ive had this before and it was my transfer case. it was shot and had to by a new on for my 03 evo which i got rid of it. if that is the case gl. lol hope u find ur problem
Old Aug 31, 2007 | 10:23 PM
CO_VR4's Avatar
Whether or not you have symptoms, you could have also overstressed your stock rod bolts. The stress from significantly exceeding your redline is not very good for factory strength hardware. If you did, and you don't replace them, in a few hundred or thousand miles you'll get a unexpected rod knock and then get to rebuild (if you're lucky) or replace your motor.
Old Aug 31, 2007 | 10:35 PM
LJtech06's Avatar
thoughts on this?
might be your shift linkage or 1-2 shift synchro...it could be causing the 1-2 shift synchro to not engage fully creating gear chatter..thats best case scenario...ive never heard of it sounding like a plane tho..definatly get the tranny checked out
Old Sep 2, 2007 | 11:13 AM
r0sco1234's Avatar
get that sh*t checked out right away
tdusffx
Sep 10, 2015 11:18 PM
HornstarBU
Lancer Engine Management / Tuning Forums
Apr 12, 2011 07:35 AM
Wicked E
12
Dec 1, 2007 05:10 AM
FeRRarI eAtR714
25
Dec 20, 2005 10:34 PM
DocMortal
Jan 28, 2004 05:48 AM
