Tranny whine in 1st gear only
Old Nov 30, 2007 | 04:01 PM
Wicked E's Avatar
I have a very loud tranny whine when starting in first from a dead stop between 1K and 2750 rpm. It is not as loud in 2nd gear... My question is, is this the start of the t-case death rally?
Old Nov 30, 2007 | 04:06 PM
20Grockit's Avatar
it could very well be. have it checked by a tranny shop. it usually doesnt cost that much to run a diagnostics test on it. i dont know about where you live but sometimes you can find coupons for a free tranny check in the newspaper and other little oddball mags
Old Nov 30, 2007 | 04:08 PM
dancarroll0283's Avatar
The Transfer case is the loudest usually at about 60-70 mph..... Alot of the 5 speed tranny's are really loud in first gear only.... It sounds like reverse.... I've gone through 2 transfer cases, and it whines anytime the car is in gear rolling, just gets louder as you go faster.... My tranny at this time has a whining noise in first gear, and always has.... Did it just get louder from what it was before? Or has it never made this noise until now? 5 speed, or 6 speed?
Old Nov 30, 2007 | 04:22 PM
Wicked E's Avatar
Yes is sounds exactly like my SR20 did in reverse. It gets louder in first if you roll into it. But doesn't seem to do it in other gears. Just a tiny bit in 2nd if low rpm. I just happened to notice it as I have been paying more attention to my car and stuff while getting a tune worked out. You know, the proverbial paranoia...
It is a 5 speed EVO IX.
Old Nov 30, 2007 | 05:58 PM
EVIL_EVO_VIII's Avatar
Its normal for Evos to do that. Ive owned 3 Evos and ALL of them did it... The gears are loud by the way they are cut
Old Nov 30, 2007 | 05:59 PM
uSmC_08's Avatar
Mine does it too in 1st gear. From what I read, it's pretty normal
Old Nov 30, 2007 | 06:12 PM
cpoevo's Avatar
The 1st gear on the Evo is realy loud because the gears are really close to being straight cut.
Old Nov 30, 2007 | 06:30 PM
Wicked E's Avatar
and I must say... A BIG sigh of relief!!
Thanks all for your help!! Much appreciated!!
Old Nov 30, 2007 | 09:12 PM
kouzman's Avatar
mine does it too! 1st gear only... others sound normal...
Sounds like straight cut which is funny....
Old Dec 1, 2007 | 01:04 AM
RoadSpike's Avatar
That is completely false straight cut gears make noise for the same reason helical cut gears make noise.
The reason the transmission makes the noise is something called "transmission error". I don't really feel like rewriting everything I've wrote about it but feel free to look it up.
Providing a link to my post:
https://www.evolutionm.net/forums/sh...64&postcount=7
Edit: found a better link to myself
Old Dec 1, 2007 | 01:23 AM
recompile's Avatar
They all do it, it's normal :-D
Old Dec 1, 2007 | 05:04 AM
CrackerJackToy's Avatar
Straight cut first gear, nothing to worry about bro.
Old Dec 1, 2007 | 05:10 AM
evoDON's Avatar
my car does the same thing. i never really thought to much about it. good to know nothing is wrong. 1st gear and second gear a little
Dmx3alo
May 26, 2017 11:11 AM
TurboIX
25
Nov 1, 2010 07:52 PM
just a neon
11
Mar 29, 2007 05:55 AM
TeStUdO
14
Jun 30, 2006 08:11 AM
Mach 8
Nov 9, 2004 05:00 PM
