No lift to shift mod on stock ECU VIDEO!!!
Old Sep 28, 2007 | 08:09 PM
4TUN8's Avatar
A big shout out to Tephra who is the creator of this ECU Mod, this guy really knows his stuff and you can see first hand the difference it makes.
http://www.youtube.com/watch?v=k9N7liGEC-k
If youtube is blocked at work or what ever, here's a different download location
http://media.putfile.com/Tephra-no-l...hift-stock-ecu
Like I said before, everyone that does this mod owes Tephra big.
Old Sep 28, 2007 | 08:18 PM
grenade's Avatar
Looks cool, is this mod out for all Ecus?
Old Sep 28, 2007 | 08:22 PM
EvoJoeIX's Avatar
I Need It!!!!
Old Sep 28, 2007 | 08:28 PM
svtkiller's Avatar
rpms still look like there dropping the same to me. I don't see any difference at all.
Old Sep 28, 2007 | 08:29 PM
4TUN8's Avatar
watch the boost gauge.
Old Sep 28, 2007 | 08:30 PM
Exciting News's Avatar
Thumbs up to Tephra. Looking forward to this to trickle down to my ECU...
Old Sep 28, 2007 | 08:32 PM
gbmoto313's Avatar
Where do i get it?
Old Sep 28, 2007 | 08:34 PM
geezer's Avatar
I heard the rev limiter which means he still uses clutch but doesn't lift throttle.
Old Sep 28, 2007 | 08:40 PM
Sr20kidD's Avatar
um... look at his gas gauge lol
THUB's Avatar
UM... Am i missing something here? I can shift without lifting off the gas right now. I don't because it's massively abusive. faster, yea, better? only if somebody else buys your transmissions.
Old Sep 28, 2007 | 08:41 PM
0E3vobutt3r's Avatar
agreed just looks like hes power shifting.. flat shift, what ever you want to call it
Old Sep 28, 2007 | 08:45 PM
EvoJoeIX's Avatar
the whole point behind no lift is you can shift without losing all your boost....
therefor makes you car faster because you no longer have to build boost in every gear
from what i hear, you can also have no lift to shift to wear it drops the rpms almost exactly where they would be when you let off the gas to shift. so its like a perfect shift everytime. its not set-up this way in the video
its not just power shifting, this has a lot less strain on the transmission
Old Sep 28, 2007 | 09:05 PM
KillaItalian904's Avatar
im getting this ASAP, seems it would help me out with my 2nd gear lockout, so the RPMS wont climb so high when i miss a gear
Old Sep 28, 2007 | 09:20 PM
DeeezNuuuts83's Avatar
Can somebody elaborate on this? I don't understand what the mod is.
Yes, I do realize that the difference in the two clips in the video is that boost is maintained, but since all I see is gauges and all I hear is sounds, all that most of us can assume is that the guy is power-shifting with the rpms bouncing off of the limiter or whatever during the shift when the gas pedal is floored. What can you do in this setup that you can't do in an otherwise stock Evo?
Not passing judgment, just asking for a little clarification.
Old Sep 28, 2007 | 09:23 PM
bigric09's Avatar
alright, in a nutshell, this patch allows you to shift without letting off the gas, still drops the rpms down a desired level, say 1500 rpm's but you dont lose boost, taking a long spool up time out of the equation. It works. I did mine today.... pretty nice. Do a search in the ecuflash thread and you will see his post
tephra, great work man.... i will be sending you some cash shortly
