psi question
Old Oct 1, 2007 | 03:21 PM
oobensin's Avatar
psi question
hey guys... here are my mods
HKS drop In
Perrin 3 in catback n dp
UR test pipe
halman mbc
jestr flash
im just curious to wat psi i should set it at.
i had jestr do my flash and he said i could turn it up all the way to 24 buttttt. lol im on my stock clutch so i know thats not a good idea...just a few questions on maybe where i should set my boost. and as well as what whp will my stock clutch hold up to with just daily driving not launching the car or anything. i have about 14k on the car. pretty decent driver ive heard that the stocker can hold up to 350whp?
Old Oct 1, 2007 | 03:25 PM
kaonashi's Avatar
it doesnt have as much to do with your clutch as it does with your gas, you have 93 octane gas? if so thats what my psi is set at.
btw you still might want to look for a clutch sooner or later
Old Oct 1, 2007 | 03:29 PM
amscrazy's Avatar
lol i got 414whp and im runnin wit da stocker...no slipage...ima upgrade soon for the hell of it but its holdin up great
Old Oct 1, 2007 | 03:32 PM
Jakeg97's Avatar
24psi sounds good
Old Oct 1, 2007 | 03:36 PM
oobensin's Avatar
lol 414whp with the stock clutch... first time ive heard numbers that high with the stock clutch any of you guys have an estimate of if im set at 24psi what kinda whp u think im putting down? 300? roughly maybe more?
and yes im using 93 octane
Old Oct 1, 2007 | 04:35 PM
gsrboi80's Avatar
your probably at the 330 mark. Id get a fuel pump if I were you boosting 24 psi
Old Oct 2, 2007 | 11:03 AM
oobensin's Avatar
bump.
Old Oct 2, 2007 | 11:24 AM
oobensin's Avatar
bump.
Old Oct 2, 2007 | 11:35 AM
evokel's Avatar
i have like the same thing, mines at 24-25psi
Old Oct 2, 2007 | 11:44 AM
fvaldes's Avatar
Hi, I have Buschur cat less stage 1 plus fuel pump upgrade and I am runing 92 octane. I have my boost set at 21psi., so you think I could go higher with such octane? How much and how many hp do you think I will gain?
Thanks
Old Oct 2, 2007 | 11:59 AM
ohbebe80's Avatar
How mush PSI should a IX with the same mods, running s**tty 91 oct, peak boost at? 22...23psi?
I'm definitely about to get flamed for not searching... but seems like a good time to ask!
Old Oct 2, 2007 | 12:30 PM
BenJ's Avatar
Run it as high as you can with no knock...I'm in the process of getting my car tuned as we speak and I've been told that 22-23 is doable on 91 craptane with a good tune. We'll see.
Old Oct 2, 2007 | 12:54 PM
newbieEVO8's Avatar
Exactly, it is all in the tune.
If you are not tuned to run 24psi don't.
If you want to run 24 psi, set it there record some logs and send that into your tuner to get your map adjusted.
Hope that helps.
