relocate oil line
Old Oct 16, 2007 | 02:32 PM
nubi4life's Avatar
relocate oil line
hey guys i just installed my new turbo and i was wondering if i should relocate my oil line from the banjo bolt on the front block near the head to the turbo. My oil line now is coming from the rear of the block to the turbo now. the reason why i ask is cause i keep blowing my turbos and i dont know why. i wanna get your opinion on what i should do. thanx
Old Oct 16, 2007 | 04:24 PM
FLAEVO's Avatar
what turbo are you running ,the br 35r or another.
Old Oct 16, 2007 | 04:44 PM
TempeRacerGuy's Avatar
you say you keep "blowing your turbos" what is happening? What does the turbo shop say that you send your old turbos to?
Do you have a turbo timer? is your oil line becoming coked? How is your drain routed?
One of the biggest problems I would find on turbo systems I would repair was that the oil return line had a J bend in it, or did not flow well back into the pan.
Old Oct 16, 2007 | 04:47 PM
double post
Old Oct 16, 2007 | 06:49 PM
nubi4life's Avatar
reply
im running a garrett gt35r. i have an hks turbo timer, the oil line isnt choked and the hose runs from the bottom of the turbo into the oil pan. i notice it happens every 500 miles.
Old Oct 16, 2007 | 07:13 PM
dazed01's Avatar
Are the seals blowing or is it getting a lot of play/locking up?
Old Oct 16, 2007 | 07:44 PM
nubi4life's Avatar
reply
see im in the military and im in germany on the autobahn. so i push it pretty hard. i dont use water lines to go to the turbo. but turbo trix and turbonetics said i dont have to run the turbo with water lines. could it be im pushing it hard?? cause i cruise at like 150mph. cant help it. to all you people who understand, its hard to keep a light foot when you see a ferrari f430 pass you
Old Oct 16, 2007 | 07:55 PM
cssaddictm4's Avatar
So you have a water cooled turbo with out water lines going to it? Thats not good if that is the case.
Old Oct 16, 2007 | 08:51 PM
nubi4life's Avatar
rep
you dont have to run water lines to the turbo. it depends on the setup.
Old Oct 16, 2007 | 09:45 PM
sparky's Avatar
What motor oil are you running? If I were running at sustained high engine speeds on the Autobahn in the summer I'd go with Castrol 10W-60 or Motul "Lemans" 10W-60 and an extra large oil cooler.
Old Oct 16, 2007 | 10:48 PM
nubi4life's Avatar
rep
dont forget that in germany its cold as heck. im running 10w30 on 21psi
Old Oct 17, 2007 | 02:34 PM
No, you don't HAVE to run water lines to the turbo.
You don't HAVE to wear a seatbelt
You don't HAVE to wipe your butt after you use the toilet
You don't HAVE to keep your head out of a pre-heated oven
In other words..... Even though you don't HAVE to do some things... it's a good idea.
I didn't say choked, I said coked
but are there any bends? How long is this hose? What size is it?
Now, you didn't answer us. HOW are you "blowing your turbo" are you blowing your seals? are bearings going out? are thrust bearings going out?
Here's the long and short of it. If you are damaging multiple turbos after 500 miles, it's not the turbos fault, it's the setup/use
Old Oct 25, 2007 | 06:00 AM
CandCPerformanc's Avatar
Water lines are not mandatory but a good thing to have when it comes to the length of the life of the turbo when being pushed hard for long periods of time. The housing arround the shaft seals and bearings is thinner due to the water jacket so they tend to just heat up faster under normal cruising on american highways but at high rpm for long stretches it would be much better to have the water lines hooked up. I have one customer with a Dart 2.2 vtec honda that went through 3 liquid cooled gt series turbos in less then 600 miles on each one due to the nature of his driving on the highway at 120 plus for about 4-5 mile stretches and with a honda thats cruising the rpm's are about 7k over 125mph, and it was allways the exhaust seals that failed and everytime it got warranteed I was told it was due to heat and garret told me I had to hook up the water lines .
Biggy VIII
Aug 9, 2016 03:06 PM
I4UnderPressure
49
Aug 11, 2012 04:41 AM
deeman101
Oct 5, 2011 08:47 PM
def1
11
May 14, 2011 09:14 PM
vipers
Apr 19, 2011 03:36 PM
