PROBLEM w/ my defi gauges help!
Old Oct 24, 2007 | 09:35 PM
Tracer's Avatar
Well basically I have a Defi control v II and the 60mm Boost, Oil Pressure, EGT. Well I through a cel the other day and pulled the negative cable of to reset my ecu, problem solved but now the oil pressure red light is on and the vII won't stop buzzing at me how do I reset this?
Old Oct 24, 2007 | 11:48 PM
Tracer's Avatar
anyone?
Old Oct 25, 2007 | 05:45 AM
Ivan@AMS's Avatar
Your warning is set too high now.
Set your warning lower.
IIRC, hit the warning button till the light on the OP gauge is flashing rapidly then hit the down button till the needle on the OP gauge is at the warning level you want. After a few moments of not pushing buttons, it goes back to monitor mode and you are good to go.
Old Oct 25, 2007 | 06:54 AM
Tracer's Avatar
Thanks I will give it a try
Old Oct 25, 2007 | 07:00 AM
bigric09's Avatar
im guessing your threw away the box with instructions ?
what 9 sec 240 told you is exactly right and what you need to do... my settings are as follows for those gauges
boost warning 25
egt warning 1400
oil pressure warning 10 to 20, but closer to 10
Tech tip lol.... if you just press the button once each time to move it, it moves in small increments, if you hold it down, it moves in larger increments.
Old Oct 26, 2007 | 01:11 AM
Tracer's Avatar
I did not throw it away the guys who installed it did, did not realize it till I got home.
Old Oct 26, 2007 | 01:36 AM
UT_Evo's Avatar
The instructions can also be found online. Mine came with Japanese only instructions, so i had to find them some other way. Basically you just reset your warnings to default, change them again. Easy enough. Hold down the Warn/Set button (or whatever it says, I can't remember for sure, been over 3 months) and then one of the gauges should start flashing, that means its in warnset mode. Pushing the arrows will change the level for warning. Then press enter (I think) to go to the next gauge and repeat, hold down Warn/Set to exit the mode.
And if you haven't already, look at the VSD HUD Concept II... I had one, and it was WONDERFUL.
Exciting News
Apr 10, 2011 03:31 PM
EVIL MR
Jul 16, 2008 03:14 PM
steve814
Feb 24, 2007 10:04 AM
nrcooled
Feb 11, 2007 12:45 PM
mattfl
Apr 18, 2005 02:47 PM
