Power Door Locks are not working. Help/Tips
Old Oct 26, 2007 | 10:58 AM
o2thag's Avatar
Question Power Door Locks are not working. Help/Tips
Hello.
I bought my 03 Evo 8 recently and when I got it the power door locks were not working, sort of. They work just fine when you go to lock/unlock the car with the stock remote but when you try to lock/unlock using either of the door lock buttons on the doors then they don't work. I have checked the fuses and the buttons on the doors and they look fine.
When I got the car it came with an alarm, nothing special, basically just an alarm that works with your stock anti-theft setup. This way I have two remotes, the stock one to lock/unlock the car and the alarm one to arm/disarm the car.
I am going to check the wiring, this weekend hopefully, because I think that maybe a wire was cut that wasn't suppose to be when the alarm was installed and that's why my locks only work by remote.
If anyone has any tips or any ideas on what else I can check to get this issue resolved it would be greatly appreciated.
Thanks
Old Oct 26, 2007 | 12:07 PM
spumoni1984's Avatar
sell everything you own. buy performance parts. live in your car.
Old Oct 26, 2007 | 12:11 PM
lilman8403's Avatar
yeah, check the aftermarket wiring. the wires should have been tapped right in the drivers kick. it is possible that the wires broke but when using the remote it send the signal where as the switch side would not.
o2thag's Avatar
Great tip but I was thinking something along the lines of my problem.
Old Oct 26, 2007 | 12:14 PM
o2thag's Avatar
Yeah, that's what I'm thinking. Thanks.
Old Jul 30, 2009 | 11:43 AM
anthony_86gt's Avatar
I am having the same exact problem! There was an alarm system installed when I bought the vehicle and it has all been removed. The power door lock switches inside the car do not do anything. Also the horn inside the car does not work. When I use the key remote the car locks and unlocks and the horn beeps when it locks. Any ideas?! I have checked wiring a few times as well as check every fuse. Any places to start? I was going to start a new thread, but I came across this one.
Old Nov 7, 2012 | 08:49 PM
Accountant's Avatar
Any help ?
Same issue here except the horn works. Please help
unicycle
Aug 20, 2016 08:25 AM
Ancyker
22
Apr 4, 2016 04:58 PM
spyderx
Jun 18, 2012 06:45 PM
Fractur3
Evo X How Tos / Installations
14
Oct 21, 2011 01:13 AM
stanley2
Feb 17, 2010 09:34 AM
