EVO III vs EVO IV. help?
I posted this over in the "newbie" section, 'cuz I am. But it doesn't look like that section gets much traffic. So I thought I'd bring it over here. Without the introduction.
the car: I have an old japanese classic that I've been trying to decide what to do with. I've narrowed it to 2 options: an LS1/T56 combo swap, or an AWD EVO swap. And so here I am.
My specific question immediately is this:
I see JDM half-cuts on Ebay regularly. less than 3K gets me an EVO III. $3500 gets me an EVO IV. (higher than that gets more expensive..... significanly more.) So what's the difference between the two?
I've done a little searching, but there's not a lot of info on the III. I see people posting about the IV here and there, and I know it was not available as a USM car. It seems though that parts are still available.
Here's my goals with it: I'm looking for no more than 500hp (the car won't weigh more than 2500lbs) and I can get the last 100hp of that with the bottle, if I have to. though I'd rather not. I want it to remain drivable, so my wife and I can cruise in it on the weekends.
help me out a bit, will ya?
TIA
Dan
TIA
Dan
The difference between the two is that from the evo4+ they flipped the engine 180 degrees compared to the evo1-3s, so that may or may not be an issue for you.
The evo4 engine being slightly newer and having a twin scroll turbo and also being able to use bits off evo5-9s.
With the evo3 engine I believe you can use DSM bits.
with whats been said. about engine been other way etc.. they swop it around 180 degrees . so they could fit the ayc system in the newer chassis. no other reason.
i wouldnt of thought the engine was much stronger. as they both suffer from crankwalk. as for power yes e4 has 10bhp more standard. but the e3 is lighter.. lighter is better than 10bhp..
ecu,s both carnt be flashed as easy as e5 onwards.
they both use same injectors 510,s they up i to 560,s on e5 onwards
more or less share the same brakes. as e5 onwards as brembo,s
no matter whitch modle you get e3 / e4. its still going to cost the same or their abouts to get 500bhp. for starters your going to have to fully forge the car. including cam,s and bigger turbo.. then a good remap...
karl..
karl..
And hes after a half cut for the engine and drivetrain so the fact that the evo1-3s are lighter isn't relevant here, just what is the better engine choice.
It would come down to what ever engine is easier to drop into the chassis I reckon.
That's what I'm talking about! Thanks for the input.
So if I'm getting this right:
Displacement didn't change. ONly the direction of the motor in the chassis.
Turbo changed, but if I'm to see 500hp, will I be changing the turbo on either one? or is that twin scroll unit on the e4 capable of doing that?
Neither are easily "flashed". So are there aftermarket ECM's available that I might look at using? OR is there a way around this?
Both have the same brakes, (and I'd assume suspension bits, or at least "layout") but the e4 has the AYC. Which is important, since the half cuts often come with the rear dif as well. Any comments on the AYC? With the amount of track time I've seen, and that this car is likely to see, I'm not so sure I really want it?
So if I could get some opinions on the above, that'd be awesome.
then: last but not least: Could anyone help me out with some rough measurements on the 2 cars?
Here's what I really need:
Track width. (hub to hub)
motor height (as compared to centerline of the hub)
Fore / aft measurement of the motor (also as compared to centerline of hub)
Almost anything else can be moved as I fabricate..... but those measurements are more or less "fixed". (Though I'll probably have to narrow the track a couple inches.... I'm betting I can find those couple inches somewhere.)
thanks for all your help. I'll post-up pictures as I go. I've been building a rotisserie to put the body on to do the bodywork, and it should be on it by the middle of next week (I ran out of steel last night)
Dan
Dan
Yeah, as I read-up on the AYC, I'm really unconvinced. It reminds me of how I felt when Honda and BMW started putting ABS on their motorcycles. I really want to be able to control that myself. Granted, with the rear dif, there's not alot to control, from the drivers' perspective.... but I'd rather not be trying to second-guess a computer with it.
So the question: Can I simply disable the AYC if I use the JDM rear dif that comes with the e4 half-cut? Or does that leave me with an 'open' dif?
measurements would still be extremely helfpul at this point.
Heres something that may help a tad with the dimensions:
http://img230.imageshack.us/img230/16/evo4dimenpu8.png
Ancyker
12
Jan 21, 2016 09:10 AM
RaNGVR-4
Sep 28, 2005 02:48 PM
