ACD Lights when cold....
Old Dec 3, 2007, 07:50 PM
BABYEVO 8's Avatar
as it is now getting colder up here and I don;t drive my car that much.. I have noticed that when I start my car in the morning all three ACD lights come on and stay on until the car warms up... which can take like 10-15 mins or more... I haven't been driving the car as I am not sure what it means.. I have searched on here but no one seems to have a similar issue..
Please
Thanks!
Old Dec 3, 2007, 07:54 PM
kilgoja's Avatar
mine always light up then imidiately go off once the car cranks...as long as they aren't all 3 blinking u should be ok....call mitsu dealer and ask them
Old Dec 3, 2007, 07:58 PM
Smike's Avatar
Location: somewhere testing various tires, brakes, and suspensions.
3 lights means the ACD is running in open mode - so the front and rear axles are not locked.
ACD sticky:
https://www.evolutionm.net/forums/sh...d.php?t=175195
Ah - so now others with 05s have having ACD issues. Your not alone, my ACD usually is in the 3 light mode. Dealer couldnt figure it out either - pump works then turns off. They offered to change the pump at a tune of $2100 (for just the pump).
BABYEVO 8's Avatar
mine stay on... they don't blink but they stay on for a long time... and when it is cold so does the ABS for a few mins...
Old Dec 3, 2007, 08:00 PM
BABYEVO 8's Avatar
Originally Posted by SmikeEvo
3 lights means the ACD is running in open mod - so the front and rear axles are not locked.
Go figure... best backed warranty kicking in!
Old Dec 3, 2007, 08:09 PM
Smike's Avatar
The way the ACD works - basically soon as there is steering input it goes to open mode. Its more for stability - but coming from cars without ABS or power brakes you learn quicky how to keep a car straight when hard on the brakes. And well for me in AXing or track days, I never noticed a difference of when the ACD was there and when its not there. And since I dont drive in the snow anymore and smart in the rain - its just dead weight.
Old Dec 3, 2007, 08:30 PM
BABYEVO 8's Avatar
I will call the Dealership tomorrow... but I will keep checkin on here in case anyone has some ideas on what it means! Thanks!
Old Dec 3, 2007, 08:33 PM
wizzo 8's Avatar
Did you check the fluid level?
Old Dec 3, 2007, 08:40 PM
BABYEVO 8's Avatar
is there an easy way to check the fluid level?
Old Dec 3, 2007, 08:42 PM
wizzo 8's Avatar
Yes its the one right behind the drivers headlight under the hood. Its a red fluid. Make sure its between the low and high mark
Old Dec 3, 2007, 08:48 PM
BABYEVO 8's Avatar
it is full... just a hair or two below the FULL line
Old Dec 3, 2007, 08:49 PM
wizzo 8's Avatar
Guess you will have to call the dealer
Old Dec 3, 2007, 08:51 PM
BABYEVO 8's Avatar
Thanks for the idea... I never thought to check that... ::bangs head against wall!::
Old Dec 3, 2007, 09:13 PM
Kracka's Avatar
Mine did this once (while driving home from buying it), but I just had to turn off the car and restart it. Hasn't happened since...knock on wood!
Old Dec 3, 2007, 09:37 PM
fryedchikin's Avatar
The IX owners manual states that all 3 lights will illuminate in cold weather but the system will operate normally once the ambient temperature rises. Sounds like what you are seeing is normal and nothing to be overly concerned about..
Quick Reply: ACD Lights when cold....
