Engine Cover Cracked - Why?
Old Dec 31, 2007, 11:30 AM
InitialE's Avatar
Today I had my IX SE engine cover replaced. It was completely cracked. I wonder if anybody has had the same problem, and if you know why it happens. The fix was easy enough and under warranty, but I wonder if it's symptomatic of a worse problem. Thanks!
Old Dec 31, 2007, 11:37 AM
CPA5's Avatar
mine cracked near each screw on the right hand side....not a big deal...I'd take it to the dealer...but i don't want them to see my car unless I absolutely have to take it there.....plus I'd like to get a carbon fiber cover anyhow
Old Dec 31, 2007, 01:42 PM
barneyb's Avatar
Do you mean that piece of plastic or the valve cover?
Old Dec 31, 2007, 01:44 PM
krazirob's Avatar
so its good that you found that then.......excuse to get a newer one
Old Dec 31, 2007, 01:50 PM
SlowSportSedan's Avatar
the valve cover is suppose to be hand tight + 1 liek 3-4 pounds...
very very easy to crack and its a $300 lesson on following directions...
Old Dec 31, 2007, 02:54 PM
TouringBubble's Avatar
I've seen lots of spark plug covers cracked. The valve cover is magnesium and can be slightly brittle. I don't doubt they crack fairly often.
Old Dec 31, 2007, 05:38 PM
~BoOsTeR~'s Avatar
Yes mine cracked also. Factory plastic blows. Go CF or Billet.
Old Dec 31, 2007, 06:12 PM
nirvancol's Avatar
+1
dsm valve covers are the same way, they only require a few ft-lbs of torque. any more and they crack very easily.
Old Jan 1, 2008, 09:19 AM
InitialE's Avatar
I never messed with the cover - so perhaps it was set incorrectly at the factory. Anyway - it was under warranty, so the replacement did not cost me any $.
Old Jan 1, 2008, 10:10 AM
either way youre covered.... a friend of mine installing cams cracked his not knowing how fragile it is... yea.. sucks to make a mistake like that, cause thats really an accident part..
Old Jan 22, 2008, 01:04 PM
amstel78's Avatar
The plastic cover on my IX cracked too; right side originating from the bolt holes. The right side is also warped upwards! Time to get it replaced under warranty.... strange, must be the rapid cooling and warming in winter, as I've never touched the cover.
Old Jan 22, 2008, 01:11 PM
Billy@EnglishRacing's Avatar
not something that needs to be super tight... be gentle
Old Jan 22, 2008, 03:57 PM
93turbomax's Avatar
How many miles did ya'll have before it cracked so I know what to look for?
Old Jan 22, 2008, 04:38 PM
trish814's Avatar
haha.. mine cracked too.
Old Jan 22, 2008, 04:46 PM
gone2pimp's Avatar
same here mine is cracked over on the right hand side.. i nvr even took it off one
Quick Reply: Engine Cover Cracked - Why?
