Failed 1st oil change
Old Jan 8, 2008 | 02:50 PM
  #91
McDougal's Avatar
Originally Posted by Bimmubishi
Turn it in the loosen direction instead of the tighten direction.
My thoughts exactly. Lefty loosey righty tighty...
Old Jan 8, 2008 | 02:53 PM
  #92
vortech_g35's Avatar
Drill a hole in the bottom of the oil pan and then plug it with some gum after your done.
Old Jan 8, 2008 | 03:01 PM
  #93
Ph3n1x's Avatar
He must be a Republican who screws everything to the right.
Old Jan 8, 2008 | 03:11 PM
  #94
MR Turco's Avatar
^^^ omg best thread evAr.
Old Jan 11, 2008 | 06:57 PM
  #95
Rin Tin Tin's Avatar
Sorry for bringing this thread back... i know how everyone hates it
but i .... CHANGED MY OIL!! SUCCESSFULLY!!!
AND I GOT ONTO THE RHINO RAMP!!!
I used a pipe and bought an oil filter wrench and it worked great
The only issue i had was taking the old washer off.
That is all... and thank you for all the advice and other comments....
PS: I didnt even have to use my purse to unscrew the bolt.... score one for me
Old Jan 11, 2008 | 07:33 PM
  #96
kilgoja's Avatar
i still have never changed my washer...it's like melted to the drain plug or something....i don't think i could get it off if i tried...lol
Old Jan 11, 2008 | 07:54 PM
  #97
JDMCT9MR's Avatar
Everyone screws up their first time on something when its comes to working on a car.
Old Jan 11, 2008 | 08:44 PM
  #98
EVO X Owner-2-B's Avatar
Wasn't this thread closed by the mods?
Old Jan 12, 2008 | 08:10 AM
  #99
EvolNinja's Avatar
I just had my oil change in my Evo at 33.3K miles! It's not suppose to be changed until 34K but I rather do it now and good thing I did because the oil in there is like black! It took me about 45 min to an hour bc I thought I had to remove the front diffuser. Found out later that I just have to jack the passenger side up and it's all there!!! At first I had a hard time to remove it either but I use a longer wrench with a little muscle... I would say, get a hollow pipe about an arm length and it will be a lot easier my friend.
Old Jan 12, 2008 | 08:14 AM
  #100
Evoryder's Avatar
fused. And mine is like that also. bought another washer for $1.33 at the dealer and can't find it. Probably going to buy a new bolt and washer again and call it a day.
Old Jan 12, 2008 | 09:17 AM
  #101
AlwaysinBoost's Avatar
please tell me you are kidding.
Old Jan 12, 2008 | 09:21 AM
  #102
moreryce's Avatar
i beleive it was changed before and the interval was at 34k... is wut he ment...
Old Jan 12, 2008 | 09:23 AM
  #103
moreryce's Avatar
i just bought an alluminum washer ( Not Crush).. and havent changed it after 15+ oil changes.. no leaks...
Old Jan 12, 2008 | 11:08 AM
  #104
Change it every time and loosen it with a putty knife.
Old Jan 12, 2008 | 11:38 AM
  #105
fostytou's Avatar
EvoM Community Team
Originally Posted by jmoudry
Make sure you get a strap wrench for the filter
Strap wrenches suck. If you were really cool you wouldn't need a breaker bar because you would have a torque wrench. Then you could put the pan bolt back in to the proper tq spec so it wouldn't be so hard to get out next time, and you could put the filter on to the proper spec so that you didn't lose it or strip the housing.
Don't use a hammer to hit the wrench, thats just asking for a stripped bolt or a hole in a place you don't want it. Also don't use an adjustable, please get the right socket size. Doing 3 of your own oil changes can pay for the tq wrench, cap style filter wrench, and correct socket.
Its just and oil change, but its also just the lifeblood of a $30k car
