Failed 1st oil change
I hope you didn't break anything.
This should not be this difficult and if it continues to be you are doing something wrong, the simplest solution is that you are turning the bolt in the wrong direction. Remember you are under the car so make sure you know what you are doing.
To give you an idea my evo was brand new sitting on the lot since 06 and I got it in Nov 07 with 34 miles on it. I changed the oil at 800 miles and had no problem getting the bolt off
While ur under there, since this is takin u so long, go ahead and change out ur blinker fluid. And mite not be that bad of an idea to go and pick urself up a tap and die set, juuuuuust incase! JK man, good luck with the whole thing.
wow, just wow.
you sure its the oil drain plug your loosening and not the turbo boost drain plug? It would make sense because the turbo boost drain plug is reverse threaded, I'm surprised nobody mentioned that yet.
hopefully you double check those numbers. i know for a fact there are some typo's in the manual concerning torque specs, and in particular an incorrect unit conversion. i believe it is on the cam angle sensor bolt that goes into the cam. if i remember correctly it calls for 128ft*lb and 25N*m.... the correct answer is in N*m and either they did the wrong units or the wrong number was printed.
tap the wrench with a hammer in the right direction....
usually always works. it should never be this hard to get off, so either you or wherever did the last oil change is over tightening the bolt was to much
Maybe your evo just doesn't like the Amsoil and refuses to co-operate. Try putting a 5 qrt jug of Mobile 1 Synth in front of the car before you try again. If that doesn't work, carefully tap on the end of the wrench to get it started. (Turn counter clockwise). Also, just to be safe, I'd replace the bolt when/if you get it off. And when you put it back on or the new one. Use a torque wrench if you can. Set it to 23+-2 lb/ft torque. Good luck.
