No heat
Old Jan 17, 2008 | 01:55 PM
evotuner04's Avatar
15 Year MemberLikedLoved
No heat
I have my evo stored for the winter, but im curious to what might be causing my heater to not work, i dont wanna take it to the Mitsu. dealership cause it'll prolly cost an arm and a leg. It doesn't blow any warm air what so ever, just cold and it really sucks. So please help me out guys, thanks
Old Jan 17, 2008 | 04:32 PM
barneyb's Avatar
Two possibilities: blend door in heater box is in the AC position - the early cars had issues with the levers on the heater box; thermostat stuck open.
Old Jan 17, 2008 | 06:39 PM
XSivPSI's Avatar
Yea, not sure what years it affected but there is a TSB on the hvac controls... my 03 got fixed free of charge.
Old Jan 18, 2008 | 10:44 AM
evotuner04's Avatar
thanks guys
Old Jan 18, 2008 | 10:47 AM
evotuner04's Avatar
i've got an appt. on tuesday at mitsu. so hopefully it doesn't cost an arm and leg
Old Jan 18, 2008 | 11:55 AM
Jameson_IXMR's Avatar
Pop your head under the drivers side footwell, and look at the 2 cables to the big giant white airbox. Check which one moves when you turn the hot/cold knob, and unsnap that cable from the white airbox. Then manually move the lever/flapper and see if you get some hot air. Also make sure the engines running when your checking for heat. If that lever doesnt change the temp (within enough time for reasonable warm-up and cool-down), then its your blend door, and mitsu should change it free I think. Its a BIG pain to do, (removing almost the whole dash, not some trim, the whole freaking thing), so hope mitsu does it for you, and be sure to check for scratches and have the rep sign something. A task like that is bound to cause some scratches, (on door panels and well, all front of your interior).
Old Jan 18, 2008 | 11:57 AM
chrismnj's Avatar
+1
Old Jan 18, 2008 | 02:30 PM
evotuner04's Avatar
alrighty yeah i'll check that out guys thanks
Old Jan 19, 2008 | 09:22 AM
cnoevol's Avatar
i dnt mean to thread jack here but im having the same issue except cars overheating too and im leaking coolant. it happened last night when i was doin some spirited driving. the heater was working fine then jus got cold and car temps got higher than usual so i knew car was starting to overheat, so i stopped and noticed the coolant. it was too dark to tell where it was comin from and i havent gone outside yet. but any thoughts??
Ahegao
Aug 31, 2016 08:58 AM
3gEclipseTurbo
31
Jun 1, 2010 03:04 PM
j14mp
Apr 16, 2009 01:08 PM
nikkadanny
13
Jun 9, 2008 04:25 PM
Recon
Lancer Troubleshooting
Feb 23, 2003 03:40 PM
