406WHP stock turbo
Old Feb 14, 2008 | 10:18 PM
  #31
gunnerman's Avatar
those are awesome numbers.....nice flat powerband
Old Feb 14, 2008 | 10:19 PM
  #32
BlackTypeS's Avatar
hmmmm
Old Feb 14, 2008 | 10:22 PM
  #33
Most-Wanted's Avatar
I highly doubt at 23 PSI it put down 396.68 WHP and 388.07 WTQ on 93. I'm not saying your bs'ing us, I'm just saying I think the dyno is not accurate. Track numbers are a must The mph will tell all.
Old Feb 14, 2008 | 10:25 PM
  #34
Johnboy1065's Avatar
are those weisco pistons higher or lower compression than the stock pistons???
this could be a lot of why hes making so much power. if its higher compression you would make more power than lower compression at the same boost pressure.....right???
Old Feb 14, 2008 | 10:27 PM
  #35
ID #376's Avatar
Pistons are 9:0.1
Old Feb 14, 2008 | 10:31 PM
  #36
Originally Posted by ID #376
Pistons are 9:0.1
ok nevermind...thats not much higher compression than stock and prolly wouldnt make that big of difference
Old Feb 14, 2008 | 10:37 PM
  #37
High_PSI's Avatar
It's a higher reading dyno but so what, 1/4 mile trap speeds tell the story. Just hit the track. If you trap at 118-120MPH, then the numbers are valid. REALLY good numbers at 7000RPM's, shift at 7200 when you run, get smooth curve but no doubt at the limit.
Old Feb 14, 2008 | 10:41 PM
  #38
ID #376's Avatar
Thanks for the advise High PSI. Soon as the track opens Im going to be there.
Old Feb 14, 2008 | 10:50 PM
  #39
evo8nyc's Avatar
crazy numbers props
Old Feb 14, 2008 | 11:01 PM
  #40
khara's Avatar
Good Job
Old Feb 15, 2008 | 12:44 AM
  #41
RevMoto's Avatar
I am calling BS on this. They have tampered with the dyno. You do not have enough done to your car and turbotrix wont tune that aggressive for a customer. No cosworth cammed car has done more than 380whp. Building your motor did nothing to that. LilRico has a built motor, built head, and every bolt on possible and only made 391whp. Also Jester is a better tuner.
Old Feb 15, 2008 | 01:34 AM
  #42
ID #376's Avatar
Thats your opinion RevMoto. I got the proof and I posted it. I dont BS. There is no need for that. My car made what you saw on the dyno sheet.
Old Feb 15, 2008 | 02:03 AM
  #43
tim85851's Avatar
damn...everyone is hating.
those are very nice numbers!!! congrats!!!
Old Feb 15, 2008 | 02:08 AM
  #44
06ravenmr's Avatar
good numbers i guess ill be seeing u at e town when i get back from iraq. will be interesting
Old Feb 15, 2008 | 04:20 AM
  #45
Burklow's Avatar
Mods as follows. HKS down pipe, Helix cat delete, HKS TBE, HKS inductions system, Hallman boost control, Wiseco pistons, Manley turbo tuff rods, balance shaft removed, Cosworth 272 cams, Upper and lower IC piping and Super tech dual valve spring and Turbotrix Built and flashed.
Ah ha! I knew it... those cams are simply unstoppable.
